ac122345 Posted December 4, 2010 Report Posted December 4, 2010 If anyone could give me some feedback I would appreciate it. I just purchased (1) JL Audio 15" subwoofer. And a 700w CRUNCH Ground Pounder 2 Ch. Amp (SVC). Was wondering what was the best way to hook it up. Here are the specs. Please let me know asap. Thinking about getting a capacitor. Im running Kicker 4 gauge wiring kit with an Alpine CDA-9886 deck. I will be using a single ported Ground Shaker box. 15W0V2-4 - JL Audio 15" 4-ohm W0v2. Series Subwoofer •15" 4-ohm subwoofer •polypropylene cone with foam surround •power range: 100-500 watts RMS •peak power handling: 800 watts •frequency response: 20-200 Hz •sensitivity: 88.2 dB •Ground Pounder Series 2-Channel Amplifier •RMS Power Rating: ◦4 ohms: 87.5 watts x 2 chan. ◦2 ohms: 175 watts x 2 chan. ◦Bridged, 4 ohms: 350 watts x 1 chan. •Dynamic (Peak) Power Rating: ◦4 ohms: 175 watts x 2 chan. ◦2 ohms: 350 watts x 2 chan. ◦Bridged, 4 ohms: 700 watts x 1 chan. •Max power output: 700 watts Quote C Webbie~GO HUSKERS!
Skullz Posted December 4, 2010 Report Posted December 4, 2010 Skip the cap and the rest should be fine for the time being, you might want to do the big 3 while your at it Quote 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
Sammitch0 Posted December 4, 2010 Report Posted December 4, 2010 First off I'd send that amplifier back, you want MONOblocks for subwoofer and multiple channels for door speakers etc. I'd also suggest building a box, but since you're only running this then that might be a waste of time/money depending on how much your prefab will cost. Problem is that subwoofer is Single 4 OHM @ 500RMS and that amplifier doesn't even do 400RMS bridged @ 4OHM. Then again I guess that's all you have for choices. Id just suggest a bigger amplifier that does 500RMS @ 4OHM true power maybe Alpine or AudioPipe or Hifonics? Quote Grand Cherokee Team Backwoods Bumpers DC 15" Level 3's /w 4 Coils Pioneer deh4200ub Pioneer 3-ways Pioneer Tweeters Pioneer GM-D9500F Audiopipe 1500.1D @ 14.4v Clarion Equalizer Knuconeptz Kollosus 0ga Knuconpetz Kollosus 4ga Coming Soon: 270xp / xs1200
ac122345 Posted December 4, 2010 Author Report Posted December 4, 2010 (edited) I have a 1000w Lanzar 2 channel amp in my silverado pushing 2 xplod 10's...that be big enough? I mean I can get a 4000w amp for around $190 new. Edited December 4, 2010 by ac122345 Quote C Webbie~GO HUSKERS!
Skullz Posted December 4, 2010 Report Posted December 4, 2010 We ran 2ch amps bridged for years fine with no problems plus he already said he has it so it'll be fine for the time being bridged at 4ohm. if he wants to he can run a pair of speakers and also a sub on the amp. Quote 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
ac122345 Posted December 4, 2010 Author Report Posted December 4, 2010 We ran 2ch amps bridged for years fine with no problems plus he already said he has it so it'll be fine for the time being bridged at 4ohm. if he wants to he can run a pair of speakers and also a sub on the amp. run one set of wires from terminal to terminal on the sub then bridge it on the amp or just put it on one channel? or a neg from one side of sub and positive from the other side of sub bridged or unbridged...i guess thats what im trying to get at. my brother just blew up a 18" RE from hooking up wrong...trying to avoid that lol Quote C Webbie~GO HUSKERS!
Skullz Posted December 4, 2010 Report Posted December 4, 2010 Posititve amp on positive sub and negative amp and negative sub, you'll notice that you'll be using the outside connections on the amp that are printed + -. If you look at the amp under the screws it will say bridged and have lines to the outer terminals, you use those terminals hooking the sub up. Quote 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
ac122345 Posted December 4, 2010 Author Report Posted December 4, 2010 Posititve amp on positive sub and negative amp and negative sub, you'll notice that you'll be using the outside connections on the amp that are printed + -. If you look at the amp under the screws it will say bridged and have lines to the outer terminals, you use those terminals hooking the sub up. Ok, bridge the sub and make it 4 ohm to the amp. Got that. What I want to know is how to wire the sub in the box. There should be (2) +/- terminals on the sub itself. + -------- + - -------- - if your looking at the sub magnet UP. or just run off one set of terminals on the sub? ^wires^ Quote C Webbie~GO HUSKERS!
MrSkippyJ Posted December 4, 2010 Report Posted December 4, 2010 First off I'd send that amplifier back, you want MONOblocks for subwoofer and multiple channels for door speakers etc. I'd also suggest building a box, but since you're only running this then that might be a waste of time/money depending on how much your prefab will cost. Problem is that subwoofer is Single 4 OHM @ 500RMS and that amplifier doesn't even do 400RMS bridged @ 4OHM. Then again I guess that's all you have for choices. Id just suggest a bigger amplifier that does 500RMS @ 4OHM true power maybe Alpine or AudioPipe or Hifonics? Who says you can't use a 2 channel amp for subs? I know wiring options are simpler with monoblocks but aside from that they work just fine. 350 watts is fine for that sub, 500 watts is the max RMS you will want to give it. Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
MrSkippyJ Posted December 4, 2010 Report Posted December 4, 2010 Posititve amp on positive sub and negative amp and negative sub, you'll notice that you'll be using the outside connections on the amp that are printed + -. If you look at the amp under the screws it will say bridged and have lines to the outer terminals, you use those terminals hooking the sub up. Ok, bridge the sub and make it 4 ohm to the amp. Got that. What I want to know is how to wire the sub in the box. There should be (2) +/- terminals on the sub itself. + -------- + - -------- - if your looking at the sub magnet UP. or just run off one set of terminals on the sub? ^wires^ Pretty sure your sub is a SVC. Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
