AQ2200D
RickyFriery97
I would do the aq3500, cuz later on you can get another one and strap them. Your electrical will be fine since you have the two extra batts.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
if you strap the amps tyou need a final ohm load of 2 ohms. this will then be like each amp is @ 1ohm getting max out of each amp and well lets do the math for the current draw of each
Aq2200: 2200/14.4= 152.778amps x 2= 305.556amps for the strapped amps
Aq3500.1: 4300/14.4= 298.6111 amp of current draw
The Aq3500.1 will draw 6.9444 amps less then the strapped AQ2200's which you wont notice im sure
If you take ~(eighty)% efficiency into account, the 3500 would demand around 380 amps, just fyi.
i didn't do the efficeny factor of either setup because i can't truely know what that is FYI
Johns.jpgSuburban Coming Soon
very true
very nice amps for the price too
thanks for the help man :drinks:
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
you have 4 D2's? then get the AQ3500.1 because other wise your wither be running the stappred amps at 1ohm so .5 each OR if they are not strapped wach amp will be at 2 ohms and only give you a total of 2400 or close to it
well each two subs will be wired at 2 ohm if i got the two 2200Ds and they would be strapped then they would see half of the final ohm load witch would be 2 ohm so wouldnt each amp see 1 ohm before takin imp rise into effect? i like the idea of having only one amp and either the 2 2200D is right around the same price as 1 3500d
or a sundown 3500d for a lil more
more then likely it will be either a sundown 3500 or the audioque 3500
http://www.audioque.com/aq/?page_id=30
$750 shipped and a 1 year warranty and ive read from a few diff places they have pretty good customer service
http://www.soundsolutionsaudio.com/store/products/Sundown-Audio-SAZ%252d3500D.html
$865 free shipping but it does not say anywhere about a warranty but im sure sundown has one for it?
ive heard from ALOT of places that sundown has awesome customer service
those are my two options
no it doesn't work that way you have 4 d2 subs you can only wire then to either .25,1, or 4 ohms with one amp. When they are strapped it becomes like 1 amp. that "one" amp needs to see 2 ohms. this is so each amp is at 1 ohm. you do NOT want to ever run your amp at .25 ohms unless your strictly SPL competitor and know what the hell our doing. Either get one big amp the AQ 3500.1 (i love mine) or 4 small amps trust me i have 4 12" D2 Fi Q's i've already thougth it through
ok i get it sorry for all the questions just trying to understand everything completly the strapped amps is whats confusing me a little lol :noob:
so say if i wired em all up to one ohm that on positive and negative lead would plug into one og the two amps that are strapped then since it makes it like one big amp it makes each amp see half of the final load witch would be .5 on each amp correct? but with imp rise the amp may never see .5 ohm may be closer to 1 ohm
i dont have the electrical to run those that low well i probally could i just wouldnt lol
right now i have 4 crunch GPV2000.1s one on each sub at 1 ohm and i dont drop below 13 when cruising or at 1500-2000 RPM
but i like the idea of one amp alot easier to tune
You can really only apply imp rise to your benefit if you are burping or play only music with very extended bass notes, ei high excursion. Because everytime the sub is at rest, the amp see the real ohms off the woofer, but under excursion that is when imp rise comes into account and you can use it to your advantage if you compete or based off the music you play. And to answer your question, if you wired a strapped pair at 1 ohm, each amp will see .5 ohm, when each amp really sees .5 ohm, that is when you will normally go into some kind of protection mode or the amp will shut off or blow if not stable that low.
Evo X build log
I would do the 3500 on all four. If you keep voltage up on that amp it makes lots of power, well over 4k no problem. And if you did the strapped option, you would set one amp to master and one to slave, there is a diagram that they send with the amp that shows what to do, pretty easy to follow. And you would need a final ohm of 2 ohms to be stable. That means that since they are in a master/slave linked config, each amp will "see" half the final ohm. So at 2 ohm each amp will "see" 1 ohm, making max power, to some degree, but due to imp rise, you will not likely see max power until you get a little under 1 ohm, I have personally seen the 3500's do well over max power when the amp "saw" .7 ohm but was wired at .25 ohm.
ok one last thing is confusing me though
does each amp need to see a two ohm load then put one of em in master mode and the other on slave and then each amp will half the final ohm load to 1 ohm? or say wire all 2/4 subs to 2 ohm and only plug it into one amp?
