exactally. why would you dissconnect the positive first? if of even touches anything metal you'll short the car. you have a lot more things to touch when the pos comes off first vs the negative.
2006 Nissan Z Track.
My Feedback Thread
im not an electrical engineer but i no car electricity more then most. think about it though, if you take off the negative you can touch whatever you want. cuz you will just be touching a wire that is bolted to your body and engine block to whatever.... nothing will happen... its just a wire at that point.
but try not to get a really cheap dmm, its a very good tool and you should invest a little money into it. it will make you money if you do installs. chraftsmen sells one for like 50 bucks (i have it) and it works great. very simple and easy to use if your not good with them. and its small.
If there isn't a second battery, you will be able to do the same with the positive, it is like unplugging a device from the wall and being able to touch the pins of the device, it is no longer energized, so it doesn't matter.
Yeah, but if he isn't going to be using it often there isn't much point in spending too much on one. If he was going to be using it heaps he'd be better off spending that much.
My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build
This forum has a massive boner for ridiculous electrical upgrades.
Lol dude you just unhook the negative terminal??? and make sure its not touching the battery
WRONG you always, always, ALWAYS remove the positive terminal. If you just disconnect the negative terminal that terminal can touch ANYTHING metal and ground out.
um no you disconnect the negative so the positive doesn't ground out, who cares if the ground touches metal and "grounds out"
previously known as wenn_du_weinst aka fucking internet coward supreme.  I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
God fuckin dammit guys. Why can't we just all agree to take off both terminals. Takes 10 goddamn seconds
  • Who's Online   0 Members, 0 Anonymous, 554 Guests (See full list)
