i was told to look in to th fluke 867be multimeter
any opinions on the mulitmeter?
EDIT:
what fluke multimeter do yal use with an oscope?
Edited by RickyFriery97
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
EDIT:
Fluke is always a good way to go with multimeters, that's a very expensive model if I remember it correctly and unless you're opening a shop it isn't necessary.
As for scopes TPI-440 all the way, it is a good multimeter and a fairly easy to use oscope.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
EDIT:
i was originally looking at the tpi
my uncle was looking into it for me and he has a buddy thats get equipment for our company dealer cost and he said that was alot better unit then the tpi but its going to be for personal use and the fluke seems alot harder to use and the tpi seems like a good reliable easy unit to use
EDIT:
Yeah if I remember right the Fluke is close to a 1000 dollar multimeter at retail so even at dealer cost I'd guess it's expensive. I have a 20 dollar multimeter from vellman and it works perfectly fine. Unless you're doing industrial work, are an amp or sub builder, or an electrician you don't really NEED a fluke.
TPI is the way to go imo
Current Systems:
2011 BMW 335i
Hertz HDP1
2002 Acura Tl
Kenwood DNX9980HD
DC 3.5k
Hertz HDP4 Amp
http://www.fluke.com/fluke/usen/Portable-Oscilloscopes/Fluke-190.htm?PID=56045
this is a very nice o-scope, my school had likt 8 of them and they were awesome. very easy to use.
as for a dmm this is a nice one.
http://www.fluke.com/Fluke/usen/Digital-Multimeters/Fluke-80-Series-V.htm?PID=56135
the fluke dmm is like 500 bucks. the oscope is like 2k-3k
EDIT:
Side by side ive seena fluke be a more accurate meter. Especially if you are measuring resistance and things like that. I had a cheapo craftsman that was over a .5 ohm off from my fluke.im sorry. I bought into the cheapo meter stuff years ago and will never own a non fluke one agani.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
i want a meter with a built in oscope that
mainly i will just use it for voltage AC/DC
ohm readings
and the oscope to tune my amps and set up my headunit
the tpi scope pluse 440 is looking like a good unit for me
fluke seems very good too but more industrial type
i just need a simple multimeter with a oscope
ohm readings
there is no such thing. you can use the scope to find voltage i guess. but like i said before a scope cost 2-3k on the cheap side. so if you were looking for a dmm with a scope if there is such a thing it would cost probably 5-6k
now there are dmms with a capture feature but not the same as a o-scope. thats just reading volts, ohms, or ac current over a period of time. where a scope is frequencies and signals
ohm readings
The TPI scope plus 440 on mobile solutions is $389
I've got a sperry multimeter at home for voltage readings and ohm readings
I'll get the scope plus440 to set my headunit and to set my amp gains
  • Who's Online   0 Members, 0 Anonymous, 695 Guests (See full list)
