Look for a decent pro audio amplifier
I know about the Crown series and would love to get them, but I think they're a bit too powerful for what I need. I'm currently working on a T-Line for an eD 13kv.4 sub that's going in my living room in a 7.1 setup. I don't need a ton of power to run this single sub, but I do want the ability to expand on my home setup if I desire to do so in the future. That reason alone is why I wanted to go rack amp was because if I decide I want to do a multi sub setup its easier with a rack amp then instead of buying multiple plate amplifiers. And with the plate amp I would have had to redesign my T-Line to fit it properly. I'm looking at a few brands over on partsexpress.com and so far its between the following:
QSC GX3
Behringer EP2000
Peavey IPR 1600
Crown XLS 1000 DriveCore
Has anyone here had experience with the other brands besides Crown? If so how as the overall performance? The signal that will feed into this amp will come from a Denon AVR 1611 receiver.
2007 Chevy Suburban LT1
Pioneer AVH 5700 DVD
Diamond Audio D3 6 1/2 components
Kicker 06ZX650.4 amp
Kicker 06ZX2500.1 (x 2)
DC Sound Lab Level 4 18's with Level 5 coils
Autotek Mean Machine 400.1D (replaced)
Soon to come:
rims
body kit
flow master pipes
Confuscious say "he who say it can't be done shouldn't be bothering man busy doing it"
Now feel free to go crawl back under that rock and leave this to the professionals....
no experience with any of them, but I have used a QSC GX5, not a fan. out of those I'd take the Crown.
First Gen Xterra: Always changing
DNX 690HD
RF 360.3
RF T3002
RF T4004
RF T10001bd
Silver Flute 6.5"s
Tang Band 1" Tweeters
Sundown X18 in 7cubes net tuned to 32hz
Trust me .25 Blows your Load.
QSC GX3
Behringer EP2000
Peavey IPR 1600
How involved do you plan on getting? How much does SQ mean to you? Music with your home theater? If you're into audiophile SQ, look into Adcom amps, best bang for the buck in terms of reference SQ.. Denon receivers have good SQ, but they are notoriously underpowered. Two ways around this, pick up speakers that have an extemely high DB rating (polk audio, Boston acoustics) or add a home audio amp like the adcom.. The Adcom may be overkill in terms of price for a sub amp, but you mention expansion and in terms of SQ, these are tough to beat for the money.. They compete against brands like rotel and other high end audiophile companies but you can get them at entry level prices. Built in the USA till they went out of business, I think they were sold and the rest is history... These amps retailed for well over $1800 when new,(GFA 555MKII) you can get a GFA555 MKII or GFA5500 for around $500 or less on Ebay.. Awesome SQ, 2 channel amp, built like a sherman tank, legit 200 x 2 at 8 ohms.. Amazing SQ for home audio applications, I don't know the detailed specs but the ratings are impressive (damping, S/N ratio frequency response etc etc)
I have 1 powering a pair of Mirage M490 bookshelves with an Adcom GTP830 preamp (pseudo 7.1) and I am quite please with music as well as home theater.. The level of detail revealed by this setup is audiophile grade, nice and smooth, flat response, accurate, neutral in tone but a bit on the crisp side with detailed vocals, punchy snappy percussion. My sub is a 200 watt self powered Mirage, Mirage center channel and polk bookshelves for surround (x 4 for 7.1) Adcom GFA5500 for center and surround, it is 5 x 100 rms. My setup is sweet for music, awesome for movies. Everything except hard rock and metal sounds amazing. Metal and Hard rock gets a bit harsh, as I said, it is mostly a pretty neutral/natural almost flat sound but tends to lean a bit toward the bright side with metal or crunchy guitars.. Funk is the perfect music, drums and bass are in the living room, brass is bold and vocals are nicely detailed.. Not sure you'll get all this from a PA amp, but you are looking for a sub amp... Do yourself a favor, try one of these out on your mains then look for a PA amp on subs, if your budget permits it, your ears will love you for it..
My next step is to pick up another adcom multi channel, an asston of drivers from parts express, an electronic crossover network, I am going to send left and right main/front signal to crossover, then to amps and have an actively crossed 3 way main speaker setup with additional powered subs aside from that for serious 15HZ home theater duty. I am going to add Morel subs, and midbass/midrange to the AMTs that I own and build cabinets around them (1-12 2-6.5s and 1- Oscar Heil AMTs each for mains, in a mid tweeter mid config) and I am going to upgrade external subs to the Titanic MK 15s (tang band?) found in parts express..
Check out adcom, you won't find a better amp for the money..
QSC GX3
Behringer EP2000
Peavey IPR 1600
Right now the mains will be handled by the Denon for now. I just dropped a bit of change to get the Denon and don't want to get another amp for my mains when the Denon will fit the bill for now (roughly 35 to 40wrms per channel). The pro amp will be just for my subwoofer (low end). I'll look into that Adcom but I'm trying to say well well under $300 so paying $500 for something used isn't what I'm looking to do.
Soon to come:
rims
body kit
flow master pipes
i have looked at that crown befor for home and i myself would pick that, simple fact as its good brand, and that model has rca ins so wouldn't need a mixer to hook up your home receiver. but then again i haven't looked at the others so
From what I'm hearing from a lot of the Home Theater forums and AVS is that I can't really go wrong with the QSC, Crown or Behringer. In fact they rank the Behringer as the best out of the three. I'm just having a hard time finding any of them for under $250 new. I'll keep searching though.
Soon to come:
rims
body kit
flow master pipes
I wouldn't say Behringer is the best of the three. QSC and Crown have higher quality amplifiers, but for price/quality, Behringer does beat them. The amps are noisy at times, but not unbearable. I'm running an EP2500 in bridge mono right now to help break in my car subs until I can get out to the car and work on it, and I've had this amp for going on two years.
Out of those choices, I'd say the EP2000 would be best suited, better if you can get a used EP2000 or 2500. I got mine for $200 compared to $300-$350 retail when I got it.
POTATO!
Your right I should have said that the Behringer was the best out of the three when it came to cost/performance ratio. I'm not knocking the other three amps at all. I would love to own all three and test them out, but my cash is so thin right now. I'm trying to work out a deal with someone on craigs list now for a used Behringer EP 1500. But If I could come across one of those QSC or Crowns I'll bit at the chance. Have you thought about changing your fan out on the Behringer amp?
Soon to come:
rims
body kit
flow master pipes
i still say go with the Crown...Crown and QSC are all I will ever use in my home. I have 75,000 watts for testing and home theater in Crown and QSC amps. all the crown are D-class (nearly perfect) all the QSC are H-class (absolutely perfect)... just because you dont' NEED the power doesn't mean you can't have it. headroom is the name of the game
Principal
JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it
Right now its the cost that I don't have. If money wasn't a factor I most likely would go wit the QSC, but I could still live with the Behringer or Crown.
Soon to come:
rims
body kit
flow master pipes
