ok cool. and what exactly is the purpose for the relay? ive just never heard of anyone doing this, (i like to learn stuff) thanks
the relay takes the signal from the HU and, instead of using it to trigger the amps, it triggers the relay. The relay then passes a higher current signal through to the amps. This takes the strain off the HU. Be sure to fuse the incoming power to the fuse. pin 30 is ALWAYS the output.
Principal
JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it
ok got it, thank you for answering.
