08 Tahoe- 2 FI SP4 18s- 2 AQ 3500s
All those videos are on only 500w? Super.
Also curious about that fuse holder, each side seems to be one block of metal? So each output wire would "share" all the fuses instead of having its own fuse, so the fuses wouldn't protect it from burning up on a short?
No it's more than 500 watts I should be getting it clamped today. And metered Mayb. As for the fuse holder yea they will share the fuses. Ive seen a fuse holder similar to this one before and it worked fine.
I hate to press a point but that fuse holder won't do it's job, think about it. The point of a fuse is to protect a wire from catching on fire if it shorts. That holder seems to have room for four 300 amp fuses, for a max of 1200 amps? Now if one of the 1/0 output wires from that block shorts, none of the fuses will blow until 1200 amps are running through that wire, then they will all blow at the same time. Now I don't know the exact figure, but a 1/0 wire will certainly melt way below 1200 amps...
no its works didn't you see what he said to me he uses just anl when he is just daily driving and when he competes he switches to the mini's :good:
I don't see how the fuse holder will work either. Each fuse needs to be separate from each other, right now it's acting as one big 1200 amp fuse.
And that blows about the amp.
Pun not intended.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
Pun not intended.
I wouldn't have that much fusing on it at once
2008 TahoeHU-PioneerMids/Highs amp- sundown 200.4Mids/Highs- hertz xls, hertz ml 700, audison voce tweetsAmp-2 AQ 3500sSubs-FI SP418sAlt-singer 350Big 3 1/0
Build Log
UBL My YouTube channel
  • 1 month later...
What if he only uses one of the 4 spots for a fuse? Just because it has that many spots to use doesn't mean they all have to be used. I think the original idea was for more options since it was tailored for MECA and daily.
Cactus Sounds USA Team Captain
Multiple World Record Holders
Very nice truck and setup! Sorry to hear about your amp thou :/
06 Chrysler 300
Pioneer avh-x8500bhs
Hertz Hsk 130.4
Alpine mrp-F600
2 Dc level 4 12s
Dc 2k
Viper 5901
SHCA wiring
KnuKonceptz RCA's
SecondSkin/Fatmat
Big 3-stock alt
Thanks. I don't even care anymore, I got new amps on the way
Build Log
Wtf man you dont even update me on this lol
Hahah damn cody
She ain't that sexy. I wouldn't even let her blow me. Those 10 pounds of make up would end up all over my crotch.
you dont find dubstep, dubstep finds you
hu: Pioneer MVH - P8300BT
mids: Alpine sps-600 all four corners
highs: Addictive Audio ECST25A,Memphis PR tweeters back
sub: 15 inch crossfire bmf
box: 4 cubes at 38 hz
amp: Rockford Fosgate Power 1000 25 To Life
140.7 on a non sealed trunk car with a five channel so far (old sub audiobahn aw1505q)
Build Log
http://www.stevemead...ima-56k-beware/
Feedback
http://www.stevemead...s-bfd-feedback/
  • Who's Online   0 Members, 0 Anonymous, 2583 Guests (See full list)
