Yea I just want to do it low tuned 31hz to.34hzr
2009 Buick Lucerne CXL, Sundown SAZ-3000d,Sundown SAX 100.4,2 Shuriken SK-BT80 (80ah batts),Mechman Custom Alt (specs to be determined),Hybrid Audio Technologies Imagine I61-2,T3 Audio t2000 (2 12s) , JVC KWHDR720 (doubledin headunit w/iPhone adapter) , SecondSkin Damplifier Pro/ Speaker Tweakers......Build in progress but I have all equipment and Enclosure is going to be around 5 net @ 35hz
What size box for 4 15s? I mean should it be 12 cubes net or should it be smaller for higher power handling?
6 sa12s ported vs 6 sa 15s sealed off a saz 3000d @ 0.7 ohm goals are 145 on music 150s on tone and a flat response that is loud on all music
If it was me I would do 6 15's if they can fit under the window line like you want. My current set up is 6 SA12's and I am able to do 148-149 on 3 minute music runs with no issues. I have seen low 50's on some 30 second runs. I am able to burp around 152 with no issues. But my box was not built for burping it was built for music...
For me I would not tune under 34, no real reason.. I have tried 28, 30, 34, 38 and 42 and I prefer 34 for sure.
Here is a quick video that was taken about a year ago..
Head Unit: Alpine CDA 9887
Sub Amps: 4 RF2500's
Subs: 8 SA-12's Walled
Comp Amp: 1 RF600.2 (for now)
Comps: (4) 6.5 Punch Mid Pros and 2 Punch Pro Tweeters
Batteries: (1) XS D5100 (5) D3100
Power Cables: 2 runs of 2/0 power and ground each front to back(Try-Star)
Alternator: Dual Mechman Rhino 250's
Deadener: Fatmat / Damplifier Pro
If you're only looking for db numbers, you can tune your box high.
but for music listenings, I would tune to 30-33 Hz, not higher.
Just my 2cents!
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers :  Audison AP 8.9 with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
I would go with the six 12s ported, more motor force ftw :D Plus another 3000d in the future my put you even higher in numbers.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
Yea its gonna be daily pretty much I listen to strictly chopped and screwed debating on tuning
if your goal is 145 on music, 150 on tone then why not just go with 1 or 2 12's and build the enclosure right................ or is it just the cool factor of having 6?
Edited by Hugh G. Rection
Owner of BigAss Ports
Is really like to do a 150 on music I'm just trying to make my goal realistic
If 4 15s can handle it its cheaper ill do that
the sa series is conservatively rated, and with you only throwing a 3k at it 4 15's will take it without a problem...as long as you set your gains right and don't clip a shit ton..
c'mon now, if i was shooting an 8 year old, it wouldnt be MY 8 year old.
i recently got a Pyle PL1590BL and i was building an enclosure for it tuned to 25 hz. i didn't have any tools to cut a circle so i hit it with a big hammer.
2003 Infiniti G35 Sport Sedan
Build in Progress
  • Who's Online   0 Members, 0 Anonymous, 1533 Guests (See full list)
