Need advice from Trunk guys
Ok so heres the deal. I have a Ford Focus sedan with the rear seats removed. I have 2 15" planet audio subs on the way. They are too big to fit in the opening where the seats folded down. I was wondering what other arrangements I could do to make a decent amount of SPL. If you could rate the arrangements from best to worst. I hope I am not asking to much but I want to do this as correctly as possible.
Thanks,
Jake
hopeful noob
i had the same issue then i realized that i could put the sub facing up. like so.
(UNDER CONSTRUCTION)
Kenwood KIV-700 headunit
2 18" sundown Z.v3s
13.5^3 wall tuned @ 28hz
SAZ-3500
DC power 270amp alt
JL c2 650
AP600.4
XS 1200 under the hood
XS 3100 in the trunk
1/0 gauge
big 3
25^2ft audio technix
^^ c-fuzzy ur an idiot, my 15" soround is waay bigger cuz its a tall sorround, on top of that I HAVE A BIGGER MOTOR... oh yeah and fuck u suck my dick i got your hoes!
anywhere they want to. They cant hear anyone telling them otherwise. just because its bigger doesnt make it any different. they just piss people off faster and farther away.
I'm assuming there to tall not to wide, if thats the case just angle the box, its a lot of work sealing it off from the trunk but it's the way I went. Had the same prob. i've got a 99 Stratus and the 15's were to tall so I angled the box and sealed it off from the trunk and I had enough room width wise don't know if you do or not, like I said its a lot of work, other than that not sure wish I had some pics of it but don't have that system anymore. Just saw the vid don,t think you have enough room width wise good luck man.
Alpine 9886
Rockford mids and highs
MBQUART 4.125
2 xfl 15's
2 TRX2000.1's
Optima up front,Knetic 2400 in back
I have tried a few different ways. Form best down the worst(my setups);
subs and port forward(not sealed off)
subs up port forward
subs back port forward
I have tried slot and tube ports, and I have had better luck with tubes. I will eventually get the flares for the tubes.
06 300C 5.7 Hemi
K&N CAI
JVC KW-AVX640 6.1" DVD
DC Audio 3.5k
6 DC Audio 8"s
6 cubes 8" aero port at 32hrtz
http://www.stevemeadedesigns.com/board/topic/183798-chrysler-300c-8-build/?p=2731834#entry2731834
should have just done the big bang 12's the only way I see this workin is subs up port back or to the side
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
Ok so it was late lastnight when i posted this. I went out and did some measuring this morning. Ive got a maximum of 16.5 Height and 36" width (if i use a grinder)
hopeful noob
looks like you can squeeze them in sealed ported would be better
big 3 1/0
i've got a tiny trunk in my 02 neon with 1 15 in a 2.2 (biggest i could fit with 65 sq in of port) with sub and port on the same face of the box. After trying facing it forward (not sealed) back, and to the side, having them to the side was by far the loudest. I'd love to seal it off from the trunk but with the work that i do i need to be able to easily remove it.
edit: I would have spent a shit load on supplies building that box had i not built it without gluing and test fitted it, so make sure you test fit before gluing
Orion 2500D, Jbl Gto 75.4
Team Wolfpack Audio FSQ 15" d2, mb quart xover, tweets peerless 6.5 mids
Alpine cda-105
optima up front Knu klm 1/0
you guys forgot the easy answer.
wall it
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
