mayhbe put some seafoam in your car as well, if there is anywater in there that should clear it up
and yea gas takes to like near absolute zero to freeze i think, lol
im guessing something else, r u getting fire to all your plugs? iv e had 1 plug go bad and it sounded like it would go but never actually turned
An internal combustion engine really only needs 3 things to start, fuel, air and spark. Always check those and you'll find the problem
air? and how can i test to see if my engine infact is or isnt getting fuel?
Team Sundown Audio
**CURRENT** -- 2012 Scion tC Build Click Here
**OLD** -- 2002 Pontiac Grand AM Build Click Here
check them out, slap me a comment
2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.
Head Unit - Alpine CDA-9887
Subs - 2x Z 12 v.2s - v.3 + NS Soft parts
Amplifier - Sundown Audio SAZ-3500D
Enclosure - 3.33 Cubes tuned to 34.66hz
Front Stage - JBL P660c 6.5" Components
Rear Deck - Powerbass 4xl 6.5" Mid-Range
Front Stage Amplifier - Sundown Audio SAX-100.4D
Wires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAs
Electrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700
Videos - http://www.youtube.com/user/BeAILsTaR13
spray a bit of ether into the intake manifold. Just a small amount (about 1 second spray), anything more is asking for trouble. Also you should check spark first always.
Hammerdown... 1%
if you can find where the fuel line goes to the motor pull it off and have someone start the car and see if gas comes out... That will answer your gas questiom.. Or pull the filter and see..
2002 civic
2- 12in dc lvl5s
1- crescendo 3kwp ( 1 more on the way)
1- stock honda alt
4-xs d3100s
3-asa300.2 amps
6- PB 4XL's
4-PB l-3h tweets
and a bunch of other sh!t
the build
http://www.stevemeadedesigns.com/board/topic/74044-project-will-it-fit/
Youtube channel
http://www.youtube.com/user/slammedblackbish
how do i find out where the fuel filter is?
Team Sundown Audio
Team Sundown Audio
2002 civic
2- 12in dc lvl5s
1- stock honda alt
4-xs d3100s
3-asa300.2 amps
6- PB 4XL's
4-PB l-3h tweets
the build
Youtube channel
def not battery.
Pull the fuel line off the front of the motor and turn the ignition on to see if the fuel pump pushes fuel up and out of the line. If you have fuel delivery then you are probably looking at the problem being either spark related (sensor down as said before most likely) or possibly the fuel is not being injected into the motor for some reason (spray ether into the intake to test that one after first verifying spark).
Hammerdown... 1%
  • Who's Online   0 Members, 0 Anonymous, 1528 Guests (See full list)
