CJ18 Posted December 29, 2010 Report Posted December 29, 2010 I cant find the voltage range for the XA3000d powerbass amp. I know the new XTA series will operate from 10v-16.5v, but will the 3000s do the same?
FaTbOy911 Posted December 29, 2010 Report Posted December 29, 2010 Im shure it can do you want to put a 14v battery Had an estimate of 6400 for an alpine/clarion setup dealer said it "should" hit around 160db with the custom boxes he was going to make for me..doubtful with so much area to move but, budget is way below that any ideas on cheaper brands for that kind of Spl setup? really didnt want to try any Boss or soundstorm, thinking Quantum figure around $150 per speaker "$1800 total" and $1700 to power it, first actual big setup for the van. New MEMPHIS CAR AUDIO build 4 15s Memphis C3 2 xs power D3100 1 xs power d3400 custom fiberglass door pannel and lots more My Build
uhoh_45 Posted December 29, 2010 Report Posted December 29, 2010 i ran mine 16 volt system and they took it like champs they also like higher pre outs from the deck/line driver so higher rca input voltage and lower gain R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
OldsBoomer Posted December 29, 2010 Report Posted December 29, 2010 Thanks for this thread bro just keep giving me more reasons to get this.. how reliable are these amps guys? Suburban Coming Soon
Socky Posted December 29, 2010 Report Posted December 29, 2010 http://audioforum.termpro.com/topic/20/11112.html This is what i found, seems like they are pretty nice amps. Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell Kenwood H/U 1/0 wire, 136 amp alt 200 ah batteries 12.7 daily 2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts Mb quart 125.4 wired to 4 aura 6's 3.6 cube box tuned to 36 plays down to 23hz
uhoh_45 Posted December 29, 2010 Report Posted December 29, 2010 reliable but will shake apart if not mounted properly i love mine but ended up with only one left due to shaking apart haha ran mine on 18 volt setup at retardedly low imp R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
OldsBoomer Posted December 29, 2010 Report Posted December 29, 2010 reliable but will shake apart if not mounted properly i love mine but ended up with only one left due to shaking apart haha ran mine on 18 volt setup at retardedly low imp 18v sounds nice wish i could pul that off right now Suburban Coming Soon
CJ18 Posted December 30, 2010 Author Report Posted December 30, 2010 Sounds good guys. Thanks for the info. Its tough to find out things on vacation.
