not trying to thread jack or anythin, but, wouldnt one 16v alt with a stepdown for the rest of the car work better? i mean u could have yur 14v constant to yur amps(like yur wanting) and u would have a constant 12v system from the stepdown for the rest of the car.
You usually need two stepdowns to run a car properly. Honestly its not worth it.
but honestly it would be the "RIGHT" way to do it.
No honestly the "RIGHT" way would be either running ALL 12v, 14v, or 16v batteries. Not mixing them.
TEAM FLEX ISSUES
Car: 1985 Oldsmobile Delta 88 Royal
24" Rims
HU: 7" Carputer, Planet Audio EQ, iPhone.
Coax: T3 Audio 4" speakers
Subs: 2x 18" T3 Audio TSNS (walled)
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MB Quarts 6.5" comp set
MAYBE ADDED
2nd DC 9k
ok. well obveously he dnt have a strong enough alt to carry what the car is demanding to keep 14.4v at his amp. SOO. keeping his regular 12v for the frnt and having two stepdowns for the cars electrical, and having the 16v alt for the 14v batts in the back would keep his voltage at bay where he is wanting it. in his case hes already got 1 14v batt hes stuck with, so he would ony need the alt and the stepdowns for him to have what he is wanting.
He never said he had a 14v battery. And if he does he's not "stuck" with it, he can sell it.
And I think it's more affordable to get 2 14v batts then getting a 16v batt, alt, AND stepdowns.
TEAM FLEX ISSUES
24" Rims
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MAYBE ADDED
2nd DC 9k
I agree.
But I still vote for a better alternator.
It might even cost less than 2 14 volt batteries, and/the stepdown method.
You can not run a 12V and 14V battery on the same electrical system with out some step downs in place, or you have separate alternators to power the 12v and 14V sides. The first thing you need to look at is if your amp can take a 14V system, which will be charging in the 16.5-16.8V range.
If you are going to run 14V then it really makes no sense to try to run a 12V and 14V system. You will see some big advantages in power running with the 14V system over a 12V system, but you need to make sure your equipment will take it and you have to be able to charge at the higher rate.
Running a 16V system would have you at 16.9V fully charged with a load on them and charging at 19.2V.
r yall syin to buy two 14v batts, 1 front an 1 back?
because you shouldnt mix a 12v and a 14v
NoFearX18 said:
trainman0978 said:
y dont u just run ur 14v batt an HO alt on its own system and leave the stock charging system alone?
2007 caliber
2 Fi ssd 18's
rd audio 3250
xs power d3100 (need 2 more)
stock alt (soon to be singer 350a)
2.75:1 4th order in progress!
  • Who's Online   0 Members, 0 Anonymous, 2968 Guests (See full list)
