I need a box design for my 5 sundown audio 8s,that would go under the back seat of a 2000 silverado ext. cab.
It's a daily driver system but I would want a good box to also be loud,that's when you experts come along :drinks:
On the silverado is going to have a:
250 amp alt,
1-aq3500,
2 kinetik hc2400s,
1/0 gauge knukonceptz,
fatmat,
music would be playing off a alpine cde-102 deck,no more stock B)
These are the max. dimensions and random designs that i came up with,you guys decide for me which design would be best
and which one should i go for. I don't care how it looks as long as it gets loud and sounds clean.
I also can raise up the seat 1",that's all what it can let me,if you guys need more room.
If 5 can't fit than I'm down to go 4,but i would like to have 5 if it's possible :peepwall:
TUNING:
38HZ
NEW UPDATE ON THE BOTTOM OF THE PAGE: QUOTE #14
INFO ABOUT THE SUNDOWN AUDIO 8:
RE: 3.28 ohms (series)
FS: 41.6 Hz
Qes: 0.513
Qms: 6.606
Qts: 0.476
Le: 2.778 mH
Vas: 3.285 L
BL: 17.138 N/A
Cms: 83.341 um/N
Mms: 175.654 g
Sens: 78.476 dB @ 1w/1m
Power: 400 RMS
Depth: 5.25"
Overall basket OD (no gasket): 8.25"
Cut-out diameter (without gasket): 7.375"
Cut-out diameter (with gasket): 7.25"
Magnet diameter: 6.25"
XMAX: 16.5mm one way
INFO ABOUT THE AMP:
4 ohm power @ 1% THD 750W x 1
1 ohm power @ 1% THD 3,500W x 1
1 ohm Power @ 16V @ 1% THD 4,000W x 1
1 ohm Power @ 18V @ 1% THD5,100W x 1
1 ohm Power @ 18V @ 10% THD 6,500W x 1
Edited by deepsilencer
TEAM FLEX ISSUES,TEAM DC AUDIO
2000 Silverado Ext 1500 v.3
(Walled Silverado)
4 DC Power 270a Alts on A DC Power Quad Alt Bracket
XS Power VCM,Stinger Volt Meters
4 AA Mayhem 18s
2 DC Audio 9.0ks Strapped
1 DC Audio 175.4
4 Selenium 6.5s & 4 Selenium 8s
4 Selenium Super Tweeter st350s
72 SQ Ft Of Stinger Roadkill Expert
Alpine CDA 9887
XS Power d3400(Hood),6 XS Power d3100s(Bed)
& much more.....
2011 Meca CA State Champion & State Record Holder In M5
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
BUILD LOG.....YOUTUBE CHANNEL.....FEEDBACK
That has to be the worst chicken scratch I've ever seen ! LOL just playin Erik. I have an idea ill text you the details when I get home.
Teamflexissueslong.jpg1995 Sonoma with camper shellJVC KD-R900(12) Incriminator Audio Lethal Injection 15s
Crescendo BC5500 ( sent to me not 18v capable)(7) XS Power d1600(2) 350amp Mike Singer AltsStripper Pole FTW
Member Build Under ConstructionYoutube Videos
lol dont hate ha
and also ports can go on the sides
doesnt matter i just want a clean box design
(Walled Silverado)
4 AA Mayhem 18s
1 DC Audio 175.4
Alpine CDA 9887
& much more.....
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
is that going under a seat?
Team Flex Issues
Low tuning > God
2011 CALI AS1 STATE CHAMP
yes
(Walled Silverado)
4 AA Mayhem 18s
1 DC Audio 175.4
Alpine CDA 9887
& much more.....
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
lol dont hate ha
thats what i would do 5 across the front with 2- 6" aero ports coming out the sides
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
If you make the box taller, to the height of the back glass. Then make it less deep according to your math. You could fit 5 subs plus ports and amp I believe. Forgive my lame ass text drawing, but it's quick and easy. But you'll get the idea. When everything is in place it should line up nice if you are looking for a general clean look. Plus you can pass the amp wires straight through the box for that clean no wire look.
______________
| amp_ |
|sub |____| sub|
|sub sub sub|
|port ____ port|
|____/ \____|
wow...drawing fail
Lol
Refs-(b.f.) 99vic, WCA Rusty(x3) Nathan@XSPOWER, Ampjunkielikeme, Bread0710, AmiCreations (s.t.) REsLaPz, PandaGT(x2), Keiferacing, Juicemane (t.w.) Powski, Big gil[/center]
Build Log
http://www.stevemeadedesigns.com/board/topic/77726-sss-celica-dc-buildupdate-611-finished/
2005 subi STi 380whp 355whp
17" gold bbs
5% tint all around w/sunglare strip
JVC dvd double din
Knuconceptz 4ga wiring
XS Power!
Big 3
8" SAv2 d2
1800 audiopipe
______________
| amp_ |
|sub |____| sub|
|sub sub sub|
|port ____ port|
|____/ \____|
hes going under the seat :shrug:
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
