wow...drawing fail
No...reading fail, lol. Under the seat?
OP...under the seat is a very tight fit....does it need to be 5? 3 might work nicely....or life the seat up 2"
Edited by TeamHT
This kids truck looks pretty nice and gets down. But he only has 4 subs. And from the dimensions I dont think 5 is gonna fit.
http://www.youtube.com/watch?v=cbIB5ng1FRo
Teamflexissueslong.jpg1995 Sonoma with camper shellJVC KD-R900(12) Incriminator Audio Lethal Injection 15s
Crescendo BC5500 ( sent to me not 18v capable)(7) XS Power d1600(2) 350amp Mike Singer AltsStripper Pole FTW
Member Build Under ConstructionYoutube Videos
With an idea like this, you can't be afraid to do work and get creative. You should go buy a nice big roll of fiberglass matting and a gallon of resin. The only wood that should be used is the MDF for the five mounting rings and maybe some 2x2 to hold them in place. Cut some 1"x1" steel tubing to use as a spacer to raise that seat up that inch. I've done two extensive under seat enclosures like the one you want to do, I can talk you through what you have to do to use every bit of space your truck has to offer.
It's all gone!
The Celica Build
Feedback
If I buy something from you, DO NOT USE FEDEX!
that's what i was thinking, maybe that design can work for mine
he's from quartz hill,ca
not that far from us
his box is 3cubes
with the 2 4" aero ports on each side of the box
there aero ports length are 13" long
if i do that type of design with 5 of them while raising the seat
2"
it should look like this
it can probably work
i dont know if that's enough for 4cubes
and on the aero ports size maybe 6"
fk idk
INFO ABOUT THE SUNDOWN AUDIO 8:
RE: 3.28 ohms (series)
FS: 41.6 Hz
Qes: 0.513
Qms: 6.606
Qts: 0.476
Le: 2.778 mH
Vas: 3.285 L
BL: 17.138 N/A
Cms: 83.341 um/N
Mms: 175.654 g
Sens: 78.476 dB @ 1w/1m
Power: 400 RMS
Depth: 5.25"
Overall basket OD (no gasket): 8.25"
Cut-out diameter (without gasket): 7.375"
Cut-out diameter (with gasket): 7.25"
Magnet diameter: 6.25"
XMAX: 16.5mm one way
INFO ABOUT THE AMP:
4 ohm power @ 1% THD 750W x 1
1 ohm power @ 1% THD 3,500W x 1
1 ohm Power @ 16V @ 1% THD 4,000W x 1
1 ohm Power @ 18V @ 1% THD5,100W x 1
1 ohm Power @ 18V @ 10% THD 6,500W x 1
Edited by deepsilencer
TEAM FLEX ISSUES,TEAM DC AUDIO
2000 Silverado Ext 1500 v.3
(Walled Silverado)
4 DC Power 270a Alts on A DC Power Quad Alt Bracket
XS Power VCM,Stinger Volt Meters
4 AA Mayhem 18s
2 DC Audio 9.0ks Strapped
1 DC Audio 175.4
4 Selenium 6.5s & 4 Selenium 8s
4 Selenium Super Tweeter st350s
72 SQ Ft Of Stinger Roadkill Expert
Alpine CDA 9887
XS Power d3400(Hood),6 XS Power d3100s(Bed)
& much more.....
2011 Meca CA State Champion & State Record Holder In M5
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
BUILD LOG.....YOUTUBE CHANNEL.....FEEDBACK
If you make the box taller, to the height of the back glass. Then make it less deep according to your math. You could fit 5 subs plus ports and amp I believe. Forgive my lame ass text drawing, but it's quick and easy. But you'll get the idea. When everything is in place it should line up nice if you are looking for a general clean look. Plus you can pass the amp wires straight through the box for that clean no wire look.
______________
| amp_ |
|sub |____| sub|
|sub sub sub|
|port ____ port|
|____/ \____|
hes going under the seat :shrug:
correct :good:
(Walled Silverado)
4 AA Mayhem 18s
1 DC Audio 175.4
Alpine CDA 9887
& much more.....
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
I did that with 4 Kicker 10's (two L7's and two L5's) in a sealed box on a Lanzar Opti2000D (wired @ 0.5 ohm so just under 2KW RMS) and it was pretty nice.
If you're not afraid of splitting the seat in half you could have the box come up between the seats for more volume and put the port in it facing upwards out the top back.
Hammerdown... 1%
