Ok, so i got my AA SMD 18 in the mail the other day and when i hit it with my multimeter it reads at .7-.8 ohms per coil. i have myself a Stetsom 2k6d amplifier (the 2 ohm model) and i was wondering if i ran the SMD in series and it would make the resistance before imp rise to 1.4-1.6 ohms would it make the stetsom go into protect? i know it goes into protect pretty easily when i had the p.o.s. solox in and blew 1 coil with it wired in parallel it was quick at going into protect which is good but will this give me a problem running the SMD? i was thinking to get another 2k6d to strap them together but i really want to see if my single 2k6d will make the smd worth my while.
And another question, i cant figure out whats wrong with my voltage in my truck. i have 2 pretty new xs power batts and my voltage at the front batt is at 14.9 at idle but the batt in the back is only 12.6. i do have all the big 3 with 0 gauge and no paint on any of the ground points so why the hell is my voltage that low in the back?
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
With the 12.6 problem. Take a multimeter in the ohm mode and put one lead on the underhood battery and the other on the battery in the back. If there is an open in the wire then the meter will come up with "OL" meaning your front battery is not hooked up to the back.
i resolve to be a nicer moderator.
Tercel build R.I.P.
Eclipse build Old New
V-Dub
My feedback.
already did that, and the batt is deff hooked up in the front because when i hit really low bass notes the voltage up front will drop a little and my lights flicker for a quick second until the alt picks up the slack for that power loss. i had that problem when i first hooked it up because i forgot to put the last fuse on the power wire. stupid moment lmao. i know ppl have said on here that the more fuses you have the less power it will travel and i have 2 fuses going from the front battery positive to the rear battery positive. will that cause any loss???
that reading is normal for a 1ohm coil. if you got the D1 coil then everything seems fine.
For your voltage problem, try trickle charging your batteries overnight. What kind of alt do you have?
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
alright, i just wanted to make sure. and ill admit it, i didnt try to trickle charge the batt overnight but as it says in my sig, i have a 270 amp mechman alt that is BEAST for my truck.
Yeah, sorry I didn't look at your sig...that would have been smart of me!
That may not be the problem, but that is what I would do first to get their resting voltage up, then see if you maintain that voltage. If you don't, then something else is up.
F150:
Stock :(
Processor: DSR1
haha its all good. i have problems with reading things too :P lol. but it may not be the issue since the voltage drops .6 in the rear at full tilt but will come back up real quick when the alt kicks in. the only thing i was thinking may be the problem is i have the amp and batt grounded right to the chassis, i dont have a ground wire connecting the front batt and the rear batt. maybe thats the problem??? idk.
  • Who's Online   0 Members, 0 Anonymous, 510 Guests (See full list)
