Backyard BEADLOCK tire removal....
Another way you can do it is similar to that, but you put the driver side tire on the tire on the floor and get as close to the rim as you can. Then drive over tire. You dont have to get out a bunch of times, just once to rotate tire. Me and my buddy do this and it takes two seconds. :good:
Edited by GoHoMeUcRyBaBy
2002 Gmc Sierra 4x4
2 10" dual 2 ohm p3's
Custom box (34hz)
Kenwood eXcelon 1800 watt amp
Kennwood monitor
Polk Audio door speakers
Kenwood tweeters
Boston acoustics rear speakers
alpine 4 channel
I've also heard that you can use a hi-lift jack to break beads. Line the jack up, hook it to the truck, and lift it til the bead goes.
Your way looks more fun though. :drinks:
You can use the jack method and it works relatively fast, but this is, as odd as it is to say it, safer.
When doing it with the jack when the bead breaks loose the jack can fly off or the truck could fall down hard enough to either damage the jack or the jack could damage the truck. It works fine for standard tires but for meaty thick tires and rims, this is a better method.
Need Test Tones/Sine Waves? Click Here!
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Pioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE Audio
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
Hit me up on Facebook, if you want
  • Who's Online   2 Members, 0 Anonymous, 1181 Guests (See full list)
