I noticed my baffle flexes under high output and low freq bass. I bought a 2" circle wooden dowel and was going to put it directly in the middle of my box. question is, thats going to be inline with the middle of my port also. will this cause any disruption in the airflow going in the port? Is the brace worth it? I dont want my numbers to go down, but im curious to see if they go up. any advice will help thanks
my box
and the dowel
Edited by dc98hoe
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
four 18s is alot of flex :) i would of used allthread but i dont want to pull the box its a pain. so i needed something meaty to toe-nail into on the bottom.
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
get all thread lol
Its 34deg outside and i dont have a garage to work in so allthread isnt a option plus im too lazy :)
I can get some big allthread too up too 3' :good:
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
Sometimes a flexing baffle actually enforces the bass instead of being a loss. Especially on really low frequencies. Also if its really flexing that bad, just toe nailing and gluing the dowel at the bottom, it will eventually break loose. But no, it wont affect airflow unless its really close to the port.
Michael Hughes = 6X SPL World Champion - Loudest on the planet in db Drag, USACi, and IASCA.
a brace will mess up airflow a little. the thicker it is, the worse it will be. however, taking away flex in the box should gain. so maybe you lose .3 from a brace but you gain 1db from less flex. it will be worth it.
good luck making the joint strong though. see if you can use a jack or something to bend the box slightly. then you can slide the dowel in with some wood glue on it, then use your nails. there is going to be a lot of force on that dowel.
Almost word fer word in my text response last night ;)
  • Who's Online   0 Members, 0 Anonymous, 2930 Guests (See full list)
