i have a 15" spl suwoofer 2000w, nitro 1200w amplifier
i hooked up my system and it slamed shook the car made heads turn. but just todayi got in the car after school and it is not hitting as hard anymore it sounds like a 10"
what can cause this?
any suggestions would be great
thanks!
Sicc 2 Sicc
SMD FOR LIFE
loose connections, blown voice coil, fucked up amp, fucked up deck, fucked up rcas, etc., etc.
in other words, it could be anything. go do some troubleshooting and report back with more info
Is spl the name of the brand? Is it dual voicecoil? Could be a blown coil. How is the amp wired? Where are the gains set at?
yes it is a brand name and its a dual voice coil. i think it is the wiring i will take a look. and as i recalled last night the amp was really hot. also my deck is brand new. would it be because inm running a 18 gguage wire for speaker wires? the wires that are hooked up to the coils are ten guage. but i will go through every and get back.
Sicc 2 Sicc
SMD FOR LIFE
Dann that would make sense but his amp is hot as hell that usally means that the amp is clipping like hell
Yeah and like teamHT said just one coil could be blown, but not likely.
if he had everything maxed it probably broke the amp or is in the process of breaking
easy there rebel, there's other possibility's to make an amp hot
improper ground- wrong impudence/wiring below recommended- then as you said clipping/maxed everything... also poor ventilation and loose wiring/low voltage
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   0 Members, 0 Anonymous, 683 Guests (See full list)
