so i've searched some and am not finding much help at all...I'm building a box for 4-18's... and i'm worried about my port flexing and whatnot. I had this problem on my last box (4-15's; common port wall with outside of box)
anyway.
port is going to run along the bottom of the box; it'll be a 46x13.5" piece of MDF. The entire outside of the box is going to be double layer, should I just go ahead and double layer the port as well? is there a better way? On that 4-15 box I had; we would up putting a 2x4 in the center of the port and screwing it in, which worked, but it changed tuning and I thought it made a lot of noise.
any help is appreciated--
Clicky for build log....
2002 Tahoe
DC Power Inc 3 alt bracket with 2x230a. alts 1 stock
Eclipse CD5030
2 JL HD 600/4
4 Rockford Fosgate 2500bdcp's
4 DC Audio 18" XL's
4 Pr MB Quart Premium Components
200FT Stinger HPM 1/0
Rockford 360.2
No where near enough sound deadening
Mid-morning peeps bump....
2002 Tahoe
Eclipse CD5030
2 JL HD 600/4
4 DC Audio 18" XL's
Rockford 360.2
I have the intintion to put down a layer of resin on the entire inside of the box....when u say glass it; you mean just add a few extra layers what; to the top of the port or something ?
2002 Tahoe
Eclipse CD5030
2 JL HD 600/4
4 DC Audio 18" XL's
Rockford 360.2
You could couple peices of dowel rodes in there, the would still flow nicely, shouldnt make port noise.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
that or mdf and round over both edges. id do allthread myself all the way through the box and port
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
Awesome. Thanks.
2002 Tahoe
Eclipse CD5030
2 JL HD 600/4
4 DC Audio 18" XL's
Rockford 360.2
  • Who's Online   1 Member, 0 Anonymous, 1646 Guests (See full list)
