well seeing what u guys said. i think ima do some more math. and re-post up a different design. a 4th order. tuning on them tuned to 43hz for a low end monster?.
43hz is very high for tuning unless your competing... for lows you want to be in the LOW 30's
Currently:
* Hybrid Audio Legathia 3-Way Active Front Stage
* (2) Morel Ultimo 12's
* (2) Arc Audio 1100.1 XDi v2 (Strapped @1ohm)
* (1) Arc Audio 1200.6
* RF 360.3 DSP
he said 4th order you always tune high on them because the design of the box drops the tuning. 43hz should be good on the lows!
2007 caliber
2 Fi ssd 18's
rd audio 3250
xs power d3100 (need 2 more)
stock alt (soon to be singer 350a)
2.75:1 4th order in progress!
well i guys i started to work on a 4th order design but im havin troubles getting the space to work out for 6 15's so i got bored and went at the other box design and changed it a little to c if this style would work.
was kinda designed around dc audio lvl 3 12's. its a little small.
these are the specs for 1 ported side. and the other is identical to it
let me know what u think would this work? or still need some changes?
Edited by jake1993
Jacob Sigmund
1 dc level 4 m1 18
1 audiopipe ap1500
2 runs of knu 1/0
Alex Bennington" <[email protected] ^^^ want one one email this guy he will hook you up!
its going to act as a bandpass more than likely which is going to require its own tuning. The only way I can see it not acting like that is to keep a ton of space between the two rows of woofers. I dont mess with the bandpasses. Id check wtih dwright corona jeff and sanitarium.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
yeah i know i didn't put the sub displacement it. but the little difference it will make wont be a issue. any1 know for sure if the port length would be exrenal?
I can't see the pictures. But you do realize that 6 15's aren't a "little" difference right? Try over a cube of airspace lost to just subs.
  • Who's Online   0 Members, 0 Anonymous, 1642 Guests (See full list)
