Im going to start building a box for 2 18s this week , I havent built a box in years , what is everyone using for box terminals , I see alot of brass looking bolts , does anyone have pics or give me some direction on where to buy and or how to install them
Thanks in advance
I use regular bolts, I drill a hole in the box a little smaller than the actual bolt its self, put ur wire with your connector on then a nut and then a washer and ratchet it in the box. Then on the outside i put a washer, then a nut, then the other speaker wire w/ connector then another bolt to finish it all off.
Some people just run their wires out a small hole and seal them up with silicone, and others run them straight out the port, which IMO looks tacky and should really only be done if you have no other choice.
You can buy the bolts at Menards or anyplace that sells Nuts Bolts and Washers. I usually go with a 5 or 7/16 bolt thats about 2- 2 1/2 long with the washers and nuts to match.
06 Impala SS
Kenwood Excelon DDX593
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
Mechman 320a Alt. w/ Big 3
Lots of Second Skin Damplifier
Under Construction for 2017
I run stainless bolts. Just make sure you use 2 washer/nuts on the outside. That way you can disconnect/reconnect without loosening up the bolt inside the box making the wires flop around.
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
Thanks that sounds easy , what do you think about these i found at parts express ,http://www.parts-express.com/pe/showdetl.cfm?Partnumber=091-1246
Im sure you could make those work, just make sure you have no touching wires and you should be fine. Also for that price you could save urself the time waiting for them, by just going and getting regular nuts and bolts it would be right around the same price.
06 Impala SS
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
those owuld work but for the cost of a pair of them you can buy a whole pack at a hardware store.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
brass for me, i get it at my local hardware store
bolt head on the inside of the box, medium sized flat washer against the wood to deter wood denting from the bolt head and to give good surface contact with the ring terminal on speaker wire leading to sub terminals
on outside i do wood-washer-nut-ring terminal to amp-nut or wing nut
I bought the gold plated version of the dayton terminals you posted.
They're great quality. I was gonna do straight hardware, but changed my mind last minute.
So far I'm happy with them. No complaints.
2005 Subaru Outback Wagon Pioneer 9400BH Fi Q 15, SAZ1500dV3
The first build>>> http://www.stevemead...-outback-build/
140.9 @ 36hz Sealed on dash!
REBUILT!!! 2 Fi Q 15s, 2 SAZ1500dv3 146.9 @ 39hz dBDRA certified
Thanks ,im still thinking about getting them just because they look really nice ,it will make my box look better cosmeticly
  • Who's Online   0 Members, 0 Anonymous, 817 Guests (See full list)
