Somewhere around 14.4 lol, full tilt you'll probably be in the low 13's
c'mon now, if i was shooting an 8 year old, it wouldnt be MY 8 year old.
i recently got a Pyle PL1590BL and i was building an enclosure for it tuned to 25 hz. i didn't have any tools to cut a circle so i hit it with a big hammer.
2003 Infiniti G35 Sport Sedan
Build in Progress
^ Upgraded front battery, big 3, 2 runs of 1/0, a dual alternator setup, and 2 D3100s or similar battery.
If you want to keep 14v you need to have the same alternator output at idle as your amps pull. The moment your alternator can't keep up with the demand you will see voltage drop.
One h/o alt with 2 d3100s and an upgraded starter battery would be my first move. There is nothing wrong with 13v, if you rarely see below 13v it's probably not worth the money for you to upgrade your charging system any more. If you must have 14v you need multiple alternators.
tejcurrent
XS Power
T3
Unless you go to a 14 or 16 volt charging system and those aq amps don't like music daily in the 16 volt and up range 16.8 is the max I would take them for daily and 18 on burp.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
Whats the difference of putting the d3100 a d1400 or a d1600?
D3100 is a 12v battery----will cost you about $360
D1400 is a 14v battery----will cost you about $260
D1600 is a 16v battery----will cost you about $270
You would need 2 1400/1600s to get similar power handling capacity in watts as 1 D3100. But you also have to take into consideration that your starting voltage on a D1400 will be around 16.8v vs a D3100 voltage of 14.9.
For what it sounds like you want to do I wouldnt mess with a 14v or 16v setup. Unless you are planning on competing with whatever setup you go with, then the difference between 14.4v and 13.5v at full tilt wont be a big deal. If your voltage is a big issue for you then I think you need to look into amps that put out their rated RMS power at 12v like SounDigital.
Edited by CJ18
  • Who's Online   0 Members, 0 Anonymous, 2212 Guests (See full list)
