whooooooooooooooooooooo
fmedina
I'm interested in seeing the clamp results of the AQ.
2001 chevy cavalier
Rebuild in progress
what happens when your CD player skips and you accidentally drop a 22 hz sine bomb at an unholy volume on 7-8 year old subs? Mechanical failure floppy sub knockage on at least 2.
well...as i see the level 6 is compared to a lamborghini.....but a corvette?
i was thinking more like a chevy volt. its cute and new and "hip", but i would just rather stick my dick in a blender.........
I'd bet the 20K would put out more power then the Warhorse. I'm not exactly an Audioque fan but facts are facts. I'd also bet you would never see 20Kw out of the Audioque.
I'll take that bet any and everyday
:ninja:
When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL
I know I will never see 20,000 watts out of my AQ20ks and I am ok with that. I only needed over 10,000 per :lol: And for $1,000 I just could not pass the chance on an amp I personally love.
But according to Pioneer it was over 8,000 watts at 12.8 volts calculated impedance of 1.925 ohms
About to post clamp results of a DD m1b (basically same amplifier than a AQ1200.1) so that should help people out :)
Sick Javier!!!! Will be tuned in :drinks:
Clamp results from the Digital Designs M1b:
Here you have some pictures comparing the M1b against the M2a :)
Input Sensitivity 8V - 0.2V
Variable High Pass Filter
Variable Low Pass Filter 20Hz - 200Hz @ 24dB/Oct
Variable Sub-sonic Filter 10Hz - 50Hz @ 24dB/Oct
Variable Bass Boost
Tested Voltage 12v -14v
Tested THD ≥1%
Damping Factor
Signal to Noise >100dB
Channels 1
Cont Power at 1 ohm 1150W x 1 @ 12v
Cont Power at 2 ohm
Cont Power at 4 ohm
Bridged
Dynamic Power 2500 x 1
Efficiency thru Output 80%
Dimensions - mm 350mm L x 175mm W x 51mm H
Dimensions - inches 13-3/8 L x 6-7/8 W x 2-1/8 H....15-1/8 L w/ mounting feet
Shipping Weight 11 lbs, 5 kg
Clamp results :
Voltage drop: 13.5v
50.6 Volts
49.3 Amps
49.1 x 45 = 2209 watts BOOM!!!!
49.1 / 45 = 1.08 ohms
Termlab score, sealed on the dash @ 42 hz :
hehehehe gotta love DD amplifiers :)
2200w at 1ohm?? Wow that's almost twice the rated. That's crazy.
just remember something hommie, specs are rated at 11.9v , i got 2200 watts @ 13.5v and 1 ohm after impedance rise, if you can keep your voltage above 13, you´ll see 2000 watts from this little thing all day long!! :)
Holy tits. How much do those go for?
  • Who's Online   0 Members, 0 Anonymous, 14127 Guests (See full list)
