thecityxignites Posted January 20, 2011 Report Posted January 20, 2011 thats weird, my aq1200d is externally fused. EDIT:nevermind, i was confused. 2001 chevy cavalier Rebuild in progress what happens when your CD player skips and you accidentally drop a 22 hz sine bomb at an unholy volume on 7-8 year old subs? Mechanical failure floppy sub knockage on at least 2. well...as i see the level 6 is compared to a lamborghini.....but a corvette? i was thinking more like a chevy volt. its cute and new and "hip", but i would just rather stick my dick in a blender.........
curtdakota Posted January 20, 2011 Author Report Posted January 20, 2011 You need to put a fuse as close to the amp as possible on the power wire use an anl 250 or 200. And it will tell you in the paper work with the amp how they recommend it. ok, so once again i have some people telling me ill be fine with just the first fuse, then i have some telling me i need a second fuse closer to the amp.. what is the definitive answer? the way i look at it is.. the fuse is there for protection? correct? so.. if the first fuse next to the battery blows..which that one would blow before the one closer to the amp would anyway...then there is no power going past that point..thus saving the amp..making the second fuse pointless...but i may be totally wrong in my way of thinking, but it makes sense if you think about it like that.
01 S-10 Posted January 20, 2011 Report Posted January 20, 2011 Put it like this, for about 10 extra dollars put the fuse there and be done with it. Everyone will say something different but you never know what could happen. Those few extra dollars could potentially keep your shit from burning to the ground. TDH FTW !!!
AMI CUSTOMS Posted January 20, 2011 Report Posted January 20, 2011 If no rear battery next to the amp, then just fuse by the front battery. That will work just like intended. I was thinking you would want an extra battery next to the amp. I would. TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty
dereileak Posted January 20, 2011 Report Posted January 20, 2011 Made this just for you, If anyone sees anything wrong let me know, AFAIK it is all correct 2006 Mazda3 Hatchback Black 5 Spd ManualPioneer 4300DVD2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)Kicker 10ZX2500.1 (2845 RMS) Sub AmpKicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)Kicker KQ3 Active CrossoverKicker KQ30 EqualizerKicker 09QS60.2 Components (Woven Carbon Cones)Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -) 1/0 Gauge KNU Kollasal Flex (1 Run for -) 300 Ft Kicker X-Series 16 Gauge Speaker WireXS Power D3400 (Rear)XS Power D3100 (Front)Singer Externally Regulated Alternator (Being Built)+ The Love for Car Audio and BASS <3UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
korey_hofer Posted January 20, 2011 Report Posted January 20, 2011 By externally fused do you mean this amp has no fuses? I'm not exactly a noob, but I've never heard of such. alot of the good amps are, lets you abuse them at comps and not be limited by the fusing previously known as wenn_du_weinst aka fucking internet coward supreme. I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
Boon Posted January 20, 2011 Report Posted January 20, 2011 In my experience the fuse by the amp won't do much. If you're worried about the amp, fuse REALLY conservatively at the battery end of the wire - generally the wire's current capacity is plenty more than what the amp will ever pull. The amp's own fusing is plenty to let the amp massively shit itself and burn every single MOSFET inside it. Trust me, I've seen inside a bunch that have gone out that way. They only really save you from a massive instantaneous current spike such as if you hook the amp up backwards (most amps have 0 resistance in reverse) 10.x volts fo' life!
curtdakota Posted January 21, 2011 Author Report Posted January 21, 2011 If no rear battery next to the amp, then just fuse by the front battery. That will work just like intended. I was thinking you would want an extra battery next to the amp. I would. i dont think a second batttery will be necessary for this install, i have a hc2000 under the hood and a DC power 180 amp alt, and big 3 done it 1/0. i should see very litte voltage drop, if any at all.
AMI CUSTOMS Posted January 21, 2011 Report Posted January 21, 2011 Your call, just depends on how hard you are going to push the amp. TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty
nikoskostaras Posted January 22, 2011 Report Posted January 22, 2011 Better if you put two. The fuse in the battery (in the engine room) will protect the wire from the battery to the amplifier, and the fuse that you will put really close to amp will protect the amp circuits. 2 fuses for you not to worry all the time mate.... P.S.:And don't worry about the connections.As long as you are extra careful with them, you wont have a problem at all. LET THERE BE BASS...!
