~lesigh~ just run the woofers active and build your own crossovers, it costs like $5. http://www.the12volt.com
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
since the 2 crossovers are pre wired into the wire could i just run both crossovers and wire them in parallel ? kind of like this
the red wires go to the amp correct? if so then that will work. You can't change anything AFTER the crossover however.
Passive crossovers are designed for the specific speakers and more specifically, very specific OHM loads. You cannot change the OHM of the speakers and expect to use the crossover. You can get away with changing speakers out so long as the impedance and power handling of the speaker is the same, though I still wouldn't recommend that either.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
res the red goes to the amp, i have one crossover for each component speaker, and i wasnt sure where i wired down the load for 2 sets thank you guys for clearing this up VERY helpful
