theory1230 Posted January 29, 2011 Report Share Posted January 29, 2011 Doing a challenger two 15 inch 8 cubes only have room for 60 sq in vent ? I want to do 100 sq but won't fit . What do you guys think should I just do two 12's I'm doing firing forward Link to comment Share on other sites More sharing options...
RAM_Designs Posted January 29, 2011 Report Share Posted January 29, 2011 Yep, go with 12's instead. Unless you're dealing with (very)low xmax woofers, or flat-out don't push your equipment very hard at all, then 60in^2 isn't going to cut it and you'll get port noise easily. On a brighter note, you can probably do three 12's and have enough room for a good sized port. What 15's were you planning on using? Ryan Miskin - owner of RAM Designs I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script> 2200+ designs since March 2011... Link to comment Share on other sites More sharing options...
AI James Posted January 29, 2011 Report Share Posted January 29, 2011 how about what powers being used as well as what your trying to accomplish Link to comment Share on other sites More sharing options...
RAM_Designs Posted January 29, 2011 Report Share Posted January 29, 2011 how about what powers being used as well as what your trying to accomplish I'm guessing a loud daily driver? Ryan Miskin - owner of RAM Designs I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script> 2200+ designs since March 2011... Link to comment Share on other sites More sharing options...
Decaf Posted January 29, 2011 Report Share Posted January 29, 2011 check ur vent speed on winisd xmax and power will dictate whether u will get too much port compression try to keep it less than 17-20m/s Link to comment Share on other sites More sharing options...
bkolfo4 Posted January 30, 2011 Report Share Posted January 30, 2011 Can you get less Net volume and more port area? Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz. Link to comment Share on other sites More sharing options...
theory1230 Posted January 30, 2011 Author Report Share Posted January 30, 2011 I can do less volume but I'm firing the subs forward. The baffle is 16x34 with a hour glass shape vent in between the to subs it works out to 60 sq in. Its two small. I should just do two 12's. I can get more cone area. Link to comment Share on other sites More sharing options...
fritosaregood Posted January 30, 2011 Report Share Posted January 30, 2011 for a trunk i would do 2 12s, but if you have plenty of volume and want 15s you could angle each sub in some. what subs are you using? and what power? seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970 Link to comment Share on other sites More sharing options...
theory1230 Posted January 30, 2011 Author Report Share Posted January 30, 2011 That's a good idea angling them will probably work didn't even think of that duh !! I'm using two theory audio 15' with 4 jl audio hd 750/1. Link to comment Share on other sites More sharing options...
