So i used my scope to set my amp, set everything to flat, had it all set up, no clipping, but when i put all my settings back on my H/U, and play some songs, it clips. I did it the way meade showed in his videos.
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
3 Sundown Audio SA-12's
Alpine H/U
RF Power Comp set 6.5"
RF 3 sixty line driver
5.25 cubes @ 31hz
what do you mean by put all your settings back?
Eclipse cd7000
so your suppose to run all your settings at flat all the time???
what i do is set everything to flat.
then set amp
then put settings back, IE: LPF, HPF, and my EQ for my highs.
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
What your supposed to do is set everything flat on the HU and never touch them again.
That's not true.
My 02 Accord Wall Build
2 Sundown Audio Nightshade V1 18s --- 1 SAZ 3500
Sundown Audio 100.4 --- 4 Sundown Audio Neo-Pro 8s
Sundown Audio 125.2 --- 2 Morel MD-12 Tweeters , 2 Selenium ST-200 Tweeters
DC Power 270xp --- 4 XS Power D1200s | 1 D5100R
I just set mine with the EQ's and stuff set how I like them cause I don't have a processor or mid/high amp :shrug:
Also side note are you affiliated with the brand hostility?
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
lol no i wish i was, just a huge huge fan
but what i am doing, is it correct? how come im getting clipping after?, just curious as i just threw my new subs in, played a bunch of songs, not even getting the subs warm at all.
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
Did you set them with the vehicle off?
Also we set everything with 50 hz tones and usually set everything ( sub level etc. ) full tilt so when you crank everything you won't clip.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
changing your EQ settings to make them HIGHER, WILL clip the headunit because you're already at the verge of clean and clipped power.
  • Who's Online   0 Members, 0 Anonymous, 2106 Guests (See full list)
