running really *&^% hot
my computer has shut off on me due to over heating twice in the past week and a half my idle temps have been in the mid 50s © since i build my rig
its not overclocked im not doing anything like converting files or running heavy programs one time i was simply on the internet here is my system if it helps any
core i7 920
asus rampage III extreme
corsair h50 cooler
cooler master ucp 900
cooler master cosmos s (10 fans)
(2) 1tb caviar black HD
(4) patriot warp v2 32gb ssd
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
Man I wish I could afford an i7. But I can't think of anything. All fans running correctly and everything
core i7 920
corsair h50 cooler
what kind of case?
2004 Volkswagen GLI
1 10" Skar VVX
^^^ Looking for an amp to run it, Pm me if you have one ^^^
core i7 920
corsair h50 cooler
what kind of case?
technically i dont afford the i7 i put it on my credit card 2 years ago and have been paying for it ever since :mad:
pull the side of your case off see if that helps.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
cases are designed to circulate air flow inside of them to help cooling, removing the side will not help but will make it worse. Bad remedy is bad. What is your CPU usage at normally?
2004 Volkswagen GLI
1 10" Skar VVX
x2 this. cases are designed to flow air in a specific pattern *front to back* and if you take the side panel off it will make the airflow really inefficient.
edit: i just thought of this, did you MANUALLY apply thermal paste to the cpu? if so, you may have put too much/too little and its interfering with the heat transfer to the cpu cooler's heatsink.
  • Who's Online   0 Members, 0 Anonymous, 913 Guests (See full list)
