How to properly tune a line driver with DD1
Good Vids Brother. Makes it simple to understand.
I have the same type setup as your vids, but I actually have an additional device in the RCA path. HU to Bass Processor to EQ to Amps. I have to check each step along the way for clipping, but clean RCA output at 10 volts means squat if the Amp can't deal with it.
:drink40:
12 - 12"s in the STAY PUFT 1989 Chevy Astro
Build & Comment Log
Un-Interrupted Build Log
YouTube Channel
Chevy Trailblazer 5.1 Dolby Digital DTS Install
You have a beard of a mysterious sea captain. I would follow you to hell and back.
Nice video! I'm going to recheck everything on my system tomorrow.
2002 Honda CR-V
Alpine 9887
My Build
Rebuilding...
Second Skin Damp
4 DC XL 15's
2 DC 5ks
Singer 320 amp
6 cap banks
Sky High wire
2 VM-1's
OM-1
all under window line
Team DC Audio
Obama has a law he's trying to pass right now, trying to ban Leo for being a threat to children everywhere.
EDIT: Not in a JP kind of way.
I thought I was going to die from all the jizz filling my ears.
Is this the same step for a epicenter?
Build Under Construction
Head Unit = Kenwood DDX514
Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4
Battery = XS D3400
Wires = Kicker RCA's, 0 Gauge street wire and Stinger
Mids and Highs = Stock
Sub= Kicker L7 12"
Alternator = 220 Mechman
Sound Deadner= Fatmat and Stinger Road Kill
I have never used an epicenter, but the process should be very similar.
1- Find maximum undistorted volume on the head unit
2- Find maximum undistorted level on any in line processor or line driver
3- Find Maximum undistorted level at each amplifier, 4 channel and/or sub amp
4- Make small adjustments on both until you reach prefect undistorted signal at the amplifier
In cases such as the test I did on my bench, the maximum undistorted level that the line driver would put out was more than the amplifier would handle with the gain at 0. At this point, you back the level on the line driver/processor down until the DD1 shows no distortion. You then adjust the gain level on the amp to match.
The dd1 is a great tool, it makes setting any system almost idiot proof. It allows you to go through every piece in your vehicle and make sure that you have no distortion. The end result is a perfectly tuned system. This tool SHOULD be in every installers toolbox, no matter your skill level, this tool is the finishing touch to every install.
