Finally beat in or loss of power? HELP!! 2x ZVX15 on sk2500.1
Hey guys, i've tried everything I can think of and coming up short...
Have had these ZVX15s in for about 5 months now, LOVE THEM. When first installed, these two 15"s were L O U D.. (Thought my roof was gunna blow off)
Have them hooked up to an SK2500.1 on a box tuned to 32hz (2007 Trailblazer LT)
Up until about a week ago everything was fine
I started noticing my Skar bass knob was being really sensative (Giving off feed back thru the subs when tapped)
A few days later, when the Bass knob was turned all the way down, the subs would randomly give off feed back as if I quickly turned the knob up and then down. When music is on and the bass knob is turned down, it seems as if the 15s would randomly get more power ( Even though the knob was turned all the way down ) but only for a brief second. This will happen regularly. It just seems as if the teeth on the bass knob DO NOT want to sit on the "Low" position, if any of that makes sense.. I can try and clarify more if needed.
Now... After noticing this happen, I thought no big problem, I will just deal with it and turn the volume down instead of dealing with the knob.
I can't pinpoint EXACTLY when I noticed, but shortly after noticing the problem with the bass knob, but subs got quieter.
At first I thought it was me just getting used to the bass, or maybe they were just getting beat in,
but after running a bunch of songs thru them I just dont think that is it.
For example, when playing "On my level" by Wiz Khalifa, the 28hz is substantially quieter. When before the roof would flex and make a TON of noise, now all you hear is the subs flapping.
Don't get my wrong, I still have bass and it is still decently "loud" but I seem to be missing the "hard hitting" part of the bass
I tried to explain this the best I could.. If anyone has had the same problem or has any idea of what I could try and do to fix the problem, I would greatly appreciate it.
I've tried reconnecting and tightening all the connections, and fiddeling with the Gains, but no go so far..
Anyways, love the Skar products.. Keep up the good work
Sounds like your bass knob is going out. Might trying unplugging it and try manually turning up to see if the helps.
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
Roger that, will try and report back.
Let me know if that helps, if not please take each sub out and DMM the coils - let's make sure they are good and reading properly. Please email [email protected] and I will be more than happy to resolve this with you directly =)
Skar Audio
www.SkarAudio.com
Phone : (888) 501-7527
The knobs have an issue of going out on us after a while. That could be the simple issue, just simple wear and tear. If you pull the knob and adjust your gains properly and they sound like they did before, then that's it. Could email Skar for another knob or pick up a pac lc1 from Sonic.
pac LC1 replaced my knob a while ago. MUCH MUCH MUCH better. Way more control over bass and zero feedback.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Skar makes good quality products. Sure they will hook you up.
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
2-5.25 Satori Mids
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
2-5.25 Satori Mids
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
Same happened to me man. Took my bass knob out, and got another one from Master Will, brand new, and it did the same. Got a Pac LC-1. I love it. lol
93' Exploder
Deck:Pioneer 6400-bt
Front Stage: Crescendo PWX 8"s and Skar Audio VX1-ST per door
Amps: Sundown Audio SAZ-3500 v1 @.375 ohm daily, CT Sounds 125.2
Subwoofer: Two PSI Platform 2 18"s,Fully Loaded D1.5's
Enclosure: B Pillar Fourth Order, 3:1 ratio tuned at 46 (Designed by Low Hertz Box Designs)
Wire: All Sky High Car Audio Cable!
Alternator: Singer 250 amp Hairpin
Batteries: XS Power D975
Team Audio Connections
  • Who's Online   0 Members, 0 Anonymous, 647 Guests (See full list)
