All Activity
- Today
Jeremy009 started following 6.5" Component Speaker jl & jbl
Hey guys, in a bit of a pickle. So I had a set of JL C1 6.5s and one of the tweets got damaged but that's not the issue. My concern is the woofer. A buddy of mines has a pair of the jbl gto 609c and i really like how they sound. Now, I can simply get another pair off tweeters an all is well with my C1 woofers but I was never really to pleased with the amount of mid bass and overall clarity, response & output of the C1 woofer, but I never had an amplifier hooked up, just off head unit power so am sure they can do plenty better. I am also planning to buy a small amplifier soon. Any advise on or any experience if I should keep the C1s woofer or will I be more pleased with the JBL gtos. https://kh.jbl.com/car-speakers/GTO609C_.html https://www.jlaudio.com/products/c1-650-car-audio-speakers-c1-speaker-systems-99043 Many thanks in advance.
Box Help w/Sundown X-15 in Ford Ranger PLEASE
crispy_chick3n replied to Bogie83's topic in Subwoofers / Enclosures
put the box on the passenger side and scoot that seat forward.... its not as wide as the box you posted. the one you posted is 38 wide the one i posted is 25 wide. its up to you. i just posted one that i had made up for my old job. i could design one for you, but i do charge for the design process. if thats something you are interested in, let me know and we can iron out the details -
Bogie83 replied to Bogie83's topic in Subwoofers / Enclosures
I appreciate your input, and responding so quickly! I think the box you're describing will push my seat forward even more than the one I built though. This is the original box I built -
just do me a favor and post some pics and maybe a vid or 2 when you get it built and playing -
thats a prefab i had designed out for an audio shop i used to work for. single x15 salt 2 was the combo, but t1500bdcp should be just fine. sub and port are both on the 20" side of the box. face it up when in the cab and put the port passenger side. should get down edit: not a prefab, but a box i designed and we always had one or 2 built up... it was prefabricated when we sold it, so i just call it prefab -
- Yesterday
Bogie83 started following Box Help w/Sundown X-15 in Ford Ranger PLEASE
Does anyone have dimensions, or know of the best way to go about putting a sundown x15 in a 1998 extended cab ranger? I started by building a box to sundowns recommended size. It sounded good, but pushed my seat too far forward. So I went with a wedge style, with the sub in between seats. But I forgot to account for woofer movement. I listen to hip/hop, rebassed and decaf primarily. And want it to hit as hard as possible with what I'm working with. I've got a Fosgate t1500-1bd for now. I've got a full woodshop, and know how to build. I just don't know my way around design programs. Any help would be greatly appreciated! Thanks
Nasty-Z changed their profile photo
Nasty-Z joined the community
2 Wolffram t1 12” woofers box help plz
OuijaEight replied to OuijaEight's topic in Subwoofers / Enclosures
Nobody? -
What kind of box is needed for two Kicx GX12s?
Joe X replied to FESMO's topic in Subwoofers / Enclosures
I am talking about a sealed sub enclosure which is completely closed and air cannot go in or out of the enclosure: Your sub seems optimized to work in a sealed enclosure however it may be possible to use in ported, the advantage with ported is that is much louder for the same power as a sealed would be. - Last week
98 SNAKE EATER changed their profile photo
FESMO replied to FESMO's topic in Subwoofers / Enclosures
What's your definition of sealed? -
MarcoPT changed their profile photo
Audiohz changed their profile photo
Hi, so I had 2 wires 4AWG from +Battery/Alternator, 1 wire 4AWG from -Battery/Motor Ground and 1 wire 1/0awg from -Battery/Chassis, volts were OK and not too many unestability when playing, so i made modifications changing the 4awg from -Battery/Motor by a 1/0 wire, and added 2wire 4awg to the -Battery/Chassis of alternator, I was expecting to have a better volt stabiliy but what I found now is that the volt meter in the dash goes from 14volt - 11.5volt when I increase bass, before of this change it was also doing it but the volts didtn go that low, probaly it goes to 12-12.5volt the lower, is this normal if I added "better ground"???, in the case of subwoofer I hear that it hit better than before, just not sure if going lower in voltage is correct as the big3 supposed to improve that part, thanks. PS I hope I explain correct what I want to say
Resonant Frequency Tahoe 2 door 1997
Gerson80 replied to Gerson80's topic in SPL - SOUND PRESSURE LEVEL
Thanks Joe, Ill try a box like that, really appreciate it, my actual is with aeroport and is about 32Hz I think, so I am not that bad I just wanted to be sure that everything was OK and getting the best for those subwoofers -
Bogie83 changed their profile photo
Ak471785 changed their profile photo
Main question is can the opening of all the ports be even or do I need to have the different ports staggered in length?
Timoteo joined the community
Looking at sound quality only
Thanks I will do that when I take the subs out for finishing the box exterior. I am thinking I am going to Bondo all the screw holes, route all the edges and have it sprayed with bedliner. I normally carpet them...but I think for this application I had rather have the bedliner finish. It sounds really good so far. I have not had time to set the amp gains with my oscilloscope nor have I tuned the whole system yet. The box does not require much power to get really loud. Thanks again for all your help!!!
The sub parameters make it ideally suited for sealed, nonetheless it looks like it would work in ported but they offer no Xmax parameter so I can only speculate. -
I came up with a shared port design which is approximately what you intended to do in size and performance. Subs up in trunk cars is not recommended due to heavy trunk lid rattling, if you choose to do the subs up just do the cutouts in the top wall instead. The other thing to comment is that many european vehicles have almost air tight trunks, that would result in reduced performance, if removing your rear seats results in you being able to see the trunk, you are ok but if you see just metal, it can be a problem.
So here is a suggestion, power: to sub(s) rated, amp subsonic filter to 28Hz, minimum port clearance 4 1/2", figure is just an assembly guide: NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside. NOTE: for increased performance subs and port should be firing rearwards.
Rodenstock joined the community
So I had a flame out on one of my B2 rage subs, decided to go ahead and replace both with Sundown Audio U series 12" dvc 4ohms. These subs are rated at 1750 watts rms a piece. I am going to run them parallel to drop to one ohm. So I need a 3500watts rms @1ohm monoblock. Right now I am running a Taramps smart 3 (not the bass version). I found 3 that look like they fit the bill. Id like to get some opinions on them, because some of the brands I never dealt with, some of the brands have a series I cant find reviews for. If yall dont agree with any of the options, please recommend one for me. Thanks in advance https://www.skaraudio.com/products/rp-3500-1d-car-amplifier https://orioncaraudio.com/products/xtr3500-1dz https://ds18.com/collections/car-audio-amplifiers/products/frp-3-5k-bl?view=sl-517F06B8 https://sundownaudio.com/collections/sia-amps/products/sundown-audio-sia-3500d-smart-3500w-wide-range-car-audio-class-d-amplifier-amp https://www.dcsoundlab.com/20k-1 https://usacousticsca.com/big-ben-classD-amplifier.html
FESMO started following What kind of box is needed for two Kicx GX12s?
Hi all, I bought two Kicx GX12 and I don't know what would be the ideal box for it to play as it should and give maximum bass. I also do not understand how best to connect it, 1 ohm, 2 ohm or even more. I ask your help from you, because I know that here sit very smart people
FESMO joined the community
Just spoke with Orion. Their "support" said without running the amps in bridged mode you can't run a single remote level control. When I asked "If I run the amps in bridged mode can I run each amp independently so that I can use one bass knob and NOT wire the speakers between the two amps?" his answer was "Hahaha...you can TRY!". Awesome. At this point IF I was going to go the multiple 3000.1 route I think my plan would be an inline rca signal attenuator before the two amps, run a bass knob per amp set wide open and then breakout the clipping leds to a custom display in the dash (this was the main reason I wanted one knob....clipping indicator.). Ridiculous that in 2024 this is something not built into the amps.
Need some insight from some of the more experienced members. The scenario: I have two Fi Audio Halycon 15"s (basically the Omegas with a few more tweaks). Based on the limited information they can handle at least 4500 watts. Current amp (still building the system): Orion HCCA 3000.1 dsplx Thoughts: Plan is/was to run the two subs wired at a final 1 ohm load (they are 1 ohm dvc subs). Problem is of course impedance rise. Modelling this in Winisd it will essentially rise to 2+ ohms around the tuning frequency of my enclosure (32 hz) resulting in less than desired power output (amp dynos and clamp videos show around 4800 watts at 1 ohm with a system voltage of 14.4-ish volts which is what I am limited to in my system). That's a bit underpowered for these beasts I think. Question: Thinking of adding a second 3000.1. dsplx and using one per sub. That would allow me to wire each sub to .5 ohms which with impedance rise would present about a 1.2 ohm load to each amplifier resulting in more power PER sub. Not totally sure about this option as I am already space constrained on the amp rack AND I would need a second lithium bank and quite a bit more power runs and blocks. Alternatively: COULD ditch the 3000.1 route and move up to the Orion 12500.1 dsplx. That would fit on the rack, might need to add a second lithium bank still, but same wire runs and blocks would work. Concern is once again impedance rise as with one amp and 2 subs I would still be left with a 1 ohm wiring configuration with rise moving the effective load to 2+ ohms. Also: IF I went the two amp route, how do you control the bass level without having to go with a bass knob per amp? In-line signal attenuator? THOUGHT about strapping the two 3000.1's since that would allow me to use one bass knob, BUT once again I keep coming back to the impedance dilemma and effective output. Help appreciated!
