the temp isnt as high.. dont think it will work..
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=020-1432
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
tuned to 25 hz... stay tuned.
blazer
stroker 15
brutus bxi2006d terrible voltage drop
145.4@38HZ... SEALED LEGAL
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
my house is louder than your car...
thanks chewie,
what do you think about this?
https://www.studioelectronics.biz/sunshop/index.php?l=product_detail&p=1725
from what i was able to find from Sam Young's website, the Capacitance Tolerance of my cap is +30%/-30%
while this one i could find is +20%/-20%
how important is Capacitance Tolerance?
Edited by dugee81
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
I dont like the leads on it, but it would probably work fine. Tighter tolerances are a plus.
Hammerdown... 1%
am I the only one who see's a burnt board?
previously known as wenn_du_weinst aka fucking internet coward supreme.  I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
its refurb if that makes a difference. the amplifier worked perfectly fine 10 minutes prior to me moving the amplifier. maybe youre correct, it made me wonder. i hope not.
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
those "burns" at the foot of of the coil are soldering flux.
Hammerdown... 1%
i ordered the replacement cap, now my only problem is how do i go about disassembling the board? i got all basic screws out and whatnot, and it seems as though the board would slide out. but it doesnt budge? is there a process for assembling/disassembling amplifiers, along with the use of that white (thermal?) paste? google searching yields no solutions on how to take this beast apart. help!!! :noob:
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
please dont replace a radial cap with an axial cap.
You can go to a higher voltage cap, just make sure the uf is the same, and the cap fits in place
i made sure it was radial :)
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
eeeeer.........
From the looks of that cap I'm not super certain that it's a polarised cap. Being 250v it may be in the output section for filtering. Can you get pics of the old one from both sides? If it's meant to be non-polar and you put in a polarised one bad things will happen.
10.x volts fo' life!
  • Who's Online   0 Members, 0 Anonymous, 1083 Guests (See full list)
