onebadmonte Posted April 4, 2011 Author Report Posted April 4, 2011 Sunday, fun day. Well sort of. Hmmm, how can I put this? When I first built my box I envisioned putting my amp on the face opposite of the ports. At the time, I was going to run a Crescendo 3KWP. This was my reasoning for putting the speaker connections where I did. Well I got this silly Kicker amp and now the speaker terminals aren't going to fly. What can I say, change of plans. In the long run this is for the best as I didn't exactly think the original terminal locations through all that well and placed them too close to the speakers. Well here is a pic of my fix. Here I'm setting up the new terminal locations. Yep, setting them up in the port this time around. A pair of generic 8ga spools for speaker wire overkill. Since Digital Designs uses that direct connection what have you I'll be using these thingies. A double dee sighting. My fancy crimping tool. All wired up and ready to drop in. Here is what it looks like in the box. All connections have been gone over with some heat shrink tubing. Up close shot of what's going on in the port. I'll be utilizing these to secure the woofers down in the box. o_o I flush mounted these woofers. To make for a clean looking install I rolled the carpeting into the speaker opening. This makes for a tight fit. To keep the gasket from getting caught I'll be using these. They are thin pieces of plastic packaging material. These will make installation a breeze and will slip right out without a hitch. Here it is, woofer installed. Opps, spoke too soon. Woofers installed. Up next, the amp Warhorse vs A Pair of SMDeez build Olds Cutlass Cierra IB build 2 Fi IB3 18s
RickyFriery97 Posted April 4, 2011 Report Posted April 4, 2011 looks badass im tuned in 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
onebadmonte Posted April 5, 2011 Author Report Posted April 5, 2011 looks badass im tuned in Thanks. Warhorse vs A Pair of SMDeez build Olds Cutlass Cierra IB build 2 Fi IB3 18s
onebadmonte Posted April 5, 2011 Author Report Posted April 5, 2011 Today I'm one step closer to getting done. It wasn't a big step, but a good one none the less. Enjoy the pics. Warhorse vs A Pair of SMDeez build Olds Cutlass Cierra IB build 2 Fi IB3 18s
Spitfire2k6 Posted April 7, 2011 Report Posted April 7, 2011 damn that looks so clean! Live life to the full... Then TURN THAT BITCH UP!
zayres29 Posted April 7, 2011 Report Posted April 7, 2011 I think it would look sick for the power wire to run across the top of the box IMO Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
onebadmonte Posted April 7, 2011 Author Report Posted April 7, 2011 damn that looks so clean! Thanks. I think it would look sick for the power wire to run across the top of the box IMO It would, especially with some fat cables. In my case I'm trying to keep the wire lengths as short as possible. Plus I'm using boring ol' copper welding cable, with plain a## black sheathing. looks clean Thanks fellas. More on the way. Warhorse vs A Pair of SMDeez build Olds Cutlass Cierra IB build 2 Fi IB3 18s
IH8PunkRok Posted April 7, 2011 Report Posted April 7, 2011 at first i was like "whoa wire in the port... the fuck?" but then i was like "whoa wire in the port... not bad" clean little setup there -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
