conley916 Posted May 20, 2011 Report Posted May 20, 2011 2015 Dodge Challenger Scat Pack audio coming soon
Team Nemesis-DJ Posted May 20, 2011 Report Posted May 20, 2011 Very good attention to detail ..I like !!
claytonedberg Posted May 20, 2011 Report Posted May 20, 2011 Looking good I can't wait to start ny builf
onebadmonte Posted May 22, 2011 Author Report Posted May 22, 2011 I got some more work done today. I started painting some of the brackets and reinstalling them. One of the first ones to get done was the fuse holder bracket. One thing I did was put a dab of silicone on the fuse holder mounting screws. Just a little added security to prevent arcing since the bracket is mounted directly to ground. Here is a shot of the fat silicone bead I put down to seal the wiring chingadera. I also put a bead of silicone one the backside of the wiring chingadera for good measure. Here it is the wiring chingadera installed for good along with the cable grommets. I also got the grommet plate installed. This is where the wiring to the amps will pass through. With the grommet plate installed. I could now look at where the wiring from the battery rack is going to run to the amp. I got the rear row of the amp rack in with the batteries and buss-bars. Here is a shot of the positive side. The three bolt heads are where the cables are going to connect to. Right above them on the body I marked where the fuse holders will bolt to. The negative side is done in similar fashion. Instead of fuse holders I use some modified cable hold down brackets. Here is a shot of the evolution of the 4 cable hold down morphing into a 3 cable hold down bracket. Here is a shot of me making do with what I got. The heads of the screws I'm using to mount the fuse holders are too big to fit in the fuse holder counterbores. Since I don't have a lathe at home I used the next best thing, a cheap drill press and a file. If you dare try this yourself careful not the hit the drill chuck with the file. The last thing you want is to kick back the file into the palm of your hand. Here are a couple of shots of the installed fuse holders and ground cable hold-downs. Here is a close up of the positive side with the batteries in place. And the negative side. Warhorse vs A Pair of SMDeez build Olds Cutlass Cierra IB build 2 Fi IB3 18s
SilveradoGoesBang Posted May 22, 2011 Report Posted May 22, 2011 Dam dude your work is clean nice build "SilveradoGoesBang" http://www.stevemeadedesigns.com/board/topic/155256-silveradogoesbang-box-done-take-notes-on-bracing/ 2 FI BTL 18's CT Sounds 7k 2013 MidwestSPL Finals Xtreme 3 - 1st Place
lukaQ Posted May 23, 2011 Report Posted May 23, 2011 I hope this car never has to come apart, that would hurt me, and I have nothing to do with it Got carbon fiber dust cap???
onebadmonte Posted May 24, 2011 Author Report Posted May 24, 2011 Got a little work done today. I worked on the cabling from the battery bank to the amp. Lets start off from the battery bank to the fuse holders on the positive side. Here is a shot looking forward through the real license plate opening in the rear bumper. Looking up from the ground. Here is a shot from the amp side of the fuse holder going up and through the floor. Now lets take a look at the negative side. Here we're looking through the rear license plate opening . A shot from the ground looking up. Here is a shot of how the cables work around the body and in between the frame cross-member to get to the opening in the body floor to get to the amp. Lastly the cables through the floor and into the rear cargo area. For those wondering, the white stuff is baby powder. I cant emphasize enough how dusting the cables and grommets with it will make fishing the cables through the grommets so much easier. Warhorse vs A Pair of SMDeez build Olds Cutlass Cierra IB build 2 Fi IB3 18s
Purplehaze Posted May 24, 2011 Report Posted May 24, 2011 Damn that looks nice! You sir are one patient man! You gotta be getting close now! Btw I may "borrow" some of your ideas! Kickin' Cruiser Seller Feedback Stage 3 Dash, Door Panels,4th Order wall 4 - 15'son a DC 5.0K 2 DC 5.0K'sSolo X 15 (v.2) Sub Build
bre2ts Posted May 24, 2011 Report Posted May 24, 2011 the attn to detail in this build is ridiculous... good shit bro Feedback 1 | Feedback 2 you win some, you lose some
