langsdon2 Posted February 18, 2011 Author Report Posted February 18, 2011 well the new shipment came in friday and just for fun we decided to hook one of them up to an aq 2200d and burp it at 44 hz. It held perfectly no more probs. slamming right out of the box. I've never understood why people say it works perfectly out the box new. Well I would hope so. Usually if you have a faulty sub, it will let you know very quickly. I say that because the last 2 out of the box broke within hours. and the 3rd was display that broke within minutes Bang em if you got em
Southnash Posted February 24, 2011 Report Posted February 24, 2011 Why has no-one mentioned the wrong enclosure??? If a spider separates, it's EITHER playing the subwoofer BELOW enclosure tuning frequency or bad glue... If you separated several, then it's your enclosure... You need to address this issue & ALSO you need to allow for the suspension to loosen up before driving it at full tilt!! 3-4 hours at 1/4-1/2 rated power will help...
TeamHT Posted February 25, 2011 Report Posted February 25, 2011 That would mean all drivers would experience the same issue unless it is in fact manufacturer error. And in my experience, these subs have never needed to broken in to play full tilt properly and effectively. Tell me...does this smell like chloroform to you?
Southnash Posted February 25, 2011 Report Posted February 25, 2011 I owned the older SPLX & it did need to break in... I would still think the enclosure is at fault..Reaching beyond the mechanical limits of the speaker & taking parts with it... What power do you have? What is your enclosure tuning freq?
ChillMasterWill Posted February 25, 2011 Report Posted February 25, 2011 faulty subs...it happens to the "best" of us......sorry dude that blows no pun intended hopefully you get it all worked out...good luck William - Metter,Ga. Dad, Self Installer/Fabricator & Repair Tech, Weightlifter, Motivator, Team SKAR Audio Captain, Team Deadly Hertz Georgia Leader 99 Toyota 4Runner SR5, "Rolling Thunder" Daily Driven, No Wall, C-Pillar Build, BASS LIFE! 2K16 SBN MECA Park and Pound DB3 Champion 2K16 SBN ISPLL Real SPL Class F Champion Second Skin Damplifier Pro, Kenwood eXcelon KDC X498, Clarion EQ, Knukonceptz RCA's The Big 3, Sky High Car Audio OFC & Kicker Hyperflex Silver Tinned 1/0 Gauge Singer 340a Alt, Northstar NSB-AGM31, SMSAGM480, 12 NessCaps Super Caps Rockford Fosgate 3Sixty Line Driver, The Oval Port Tuned To 31 Hz, CNC Machined 4 SKAR ZVXv2 D2 15's, 2 SKAR SK-4500.1's, 4 SKAR PAX 6.5's, 2 SKAR LP-80.4's MEMBER OF THE YEAR 2013If you don't have any haters, get some, best motivation there is...
Farmacist Posted February 25, 2011 Report Posted February 25, 2011 I'm not going to nut hug here but the SPLX is a very goood woofer and should easily take the power. Either 2 things happened, user error... or it was in fact faulty, and I'm not ruling out the faulty one because it happens(in all companies) what I can tell you is that they can take over rated power, that I know.. a friend of mine ran 2 `12's of a xxx6500 on 16v, 1.1 ohm load after rise and he uses that daily. Team Soundstream Team Xs Power Team Secondskin Audio Team Mechman
OldsBoomer Posted February 25, 2011 Report Posted February 25, 2011 Hmm I see faulty manufactoring here, with a side of playing to low. But to everyone saying that clipping could not cause this. Im going to say wrong. Driving the sub with a clipped signal causing the coil to move past its intended points will cause additional stress on these soft parts no matter what frequency. Cheap plastic + High stress= broken plastic. Suburban Coming Soon
langsdon2 Posted April 5, 2011 Author Report Posted April 5, 2011 The problem was resolved, they had a couple other customers have the same problem. We got the new splxs with the new dustcaps. Put them both in running full tilt and have had no problems whatsoever, minus the suspension being loose. Bang em if you got em
