i only have one battery and it has been moved to the trunk, right now i have battery grounded to the strut tower in the back and a ground in front going from engine to strut tower and another going from transmission to frame, im still not getting the best of electric, voltage drops on 1kwRMS audio but i even get a bouncing gauge with turn signal, was wondering if i am having bad ground ?
LET MEH NOOES
try grounding the batteries to each other
also check for loose power wire your voltage shouldnt change if you have your blinker on
Edited by zayres29
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
only have one battery relocated to trunk
power wire is 1/0 50mm^2 welding cable
Battery ground is 1/0 welding cable
ground from engine to strut tower is 1/0 welding cable
and ground from tranny to frame is 2/0 wire ( salvaged from a hybrid car )
Edited by michigancapri92
scratch all the paint away from all the connections with wire
your best bet is drilling through and grounding directly to the frame rail.. its the thickest peice of metal on the car. and it is a straight peice from the front to back.. no spot welds for electricity to have to go through..
ground there up front and in the back.
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
tuned to 25 hz... stay tuned.
blazer
stroker 15
brutus bxi2006d terrible voltage drop
145.4@38HZ... SEALED LEGAL
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
my house is louder than your car...
all electrical and ground connections have been soldered solid and all ground locations were made with bare metal i could see a reflection in
Use a DMM to check voltage drop across LARGE parts of the car, For instance, the floor of the trunk should be a fine ground point. Any LARGE area's of metal are most likely part of the main chassis. If you are really worried about it, the rear bench seat will be bolted to the frame, those bolts are probably accesible from the trunk.
2009 Cobalt LT
Pioneer Headunit
2x Pioneer 6 1/2 (stock amp)
2x Pioneer 1" tweeters (stock amp)
2x Pioneer 6x9 (stock amp
4x Pioneer 6 1/2
Pioneer GM-6400F
Soundstream DTR 1700 R.I.P
2x Champion series PRO 12" subs
0 AWG Big 3, Stinger SP1700 battery
To come:
New or repaired DTR!!
Frame rail, or run 1/0 back to the alternator mounting bracket.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
  • Who's Online   0 Members, 0 Anonymous, 825 Guests (See full list)
