in my opinion,,. not usually.. unless you are overpowering or clipping a sub shouldnt get warm to the touch at the dustcap. Enough heat isnt being dissipated from where it should be and the heat is coming up to the dust cap. Ide say if your overpowering turn them down a bit, or recheck your gains and make sure your not clipping the sub
that is basically where the heat will build due to the voice coil being under it. subs will get warm but if they get hot and smelly you are probably clipping and that is bad.
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
it's fine...it happens. if you smell it there might be an issue with too much power or dirty signal, but heat is a natural byproduct of electricity
Principal
JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it
I set gain with a dmm but I'll turn gain down a bit I'm overpowering its a ss splx 15 rated at 1250 rms I got a hifonics brz2400 on it
www.wooferwarehouse.com
clipping came to your ride, disrespected your sub
or he's just running double the rms to the sub? Even if you're not clipping at all the 2x rms is gonna make that sub heat up..just turn your gains down
c'mon now, if i was shooting an 8 year old, it wouldnt be MY 8 year old.
i recently got a Pyle PL1590BL and i was building an enclosure for it tuned to 25 hz. i didn't have any tools to cut a circle so i hit it with a big hammer.
2003 Infiniti G35 Sport Sedan
Build in Progress
you don't know the history bro
Team Flex Issues
