hey guys i currently have 3 12" alpine type R's in a 7.2 Cu-NET box and i want to add another. is a 7.2 cu-net box too small for 4 alpine type R's?
and if i want my box tuneed to a lower freq do i make my port longer tword the wall of the inside of the box so air cant get out as easily? if its too small then im thinking of building a new box. okay my old box is tunned to 35.5 hz. it suck on lows like no flex to my mirrors. for example , the song young jeezy - count it up. strickly a 30hz tone around i think and theres no excusion and barly air movement in the vehicule. if i tune to 32 hz would it be better. ? a longer port makes the freq tune lower if im right? because i got plans for a box at 8.4 cu-net for 4 12" and he tunned it to 34 hz and i want a lower freq like 30-32 hz to hit that flexin' spot. ya know. let me know some details thanks.
Orion 2500D , 2-10" alpine type X. Custom enclosure,
Alpine amp for mids and highs.
Working on a center channel ATM
I think you would be ok with 7.2 cubes. What amp do you have and what are you settings?
2003 GMC Yukon Denali
Alpine CDA 117
Redoing Mids/Highs
4 Runs of 1/0 Knukonceptz 2+, 2-
4 Deka 9A31's in back (Stock underhood) 250 amp Alt.
AQ20K
2 18" Crossfire XS V.2's 12 cubes 33hz 149sq inches of port!
okay well i have a box tunned to 34hz how do i make it so its 32 hz? do i make the port 2 inches longer?
Well what measurements do you have to work with? What is this going in? If you could let me see what the design looks like I can help you out..
i had 4 15" alpine type rs in a sealed wall. 10.8 cubes and it was split so each pair was seeing 5.4 cubes and it SLAPPED so loud and clean
asked tons of people this same question. found the most common answer was 2.3 cubes per sub, 30 square inches of port per sub, and 34hz for tuning. Thats what I built for running 3200watts to them. loved it.
06 2500hd, 6.0L, 4l80e, 4wd, (muah work truck)
7" BDS HC lift kit
(5) 37x13.5R18 Toyo Open Country M/Ts
(5) 18x10 Moto Metal MO962
tablet in lieu of deck
blue tooth interconnect to soundstream eq (for volume control and bass control)
4 Alpine type r 10's
6 cubes net, 80sqin's port, tuned to 33hz
2 brutus brx5000.5's
2 pairs 3" polk audio for a pillars
4 pairs polk audio 6.5 comps
1 pair 8" polk audio for mids
2 xspower d3400 batteries
.....learning alot from meade and his circle of some of the baddest installers ive seen- thanks guys, for not being so cocky and posting the way it should be done!
P.S. Thanks Steve....for the demo!!!! loud as fauk!
this is the description of the box he sent me :
In order to make the internal volume correct, I had to shrink it down to 20 inches in height.
Here's what I came up with;
40Wx20Hx28D, 8.4ft^3 net, 117in^2 port area, 21.5 inches effective port length for 34hz tuning
to go with 4 subs at top with port at top
.... If i knew how to upload pics i'd send you a picture.....:( but u can see it here
http://s1142.photobucket.com/albums/n614/guimond47/?action=view&current=mybox5.jpg#!oZZ1QQcurrentZZhttp%3A%2F%2Fs1142.photobucket.com%2Falbums%2Fn614%2Fguimond47%2F%3Faction%3Dview%26current%3Dmybox5.jpg
copy and paste the link into your internet browser:)
Actually, VERY close to what my personal findings and experience show. Although I had better response with a little bit less port area
