AQ3500.1
It just has one battery under the hood.
Then just replace your starting batt with the biggest AGM you can fit, and 2 g31's in the back. You probably want to do 2 runs of 1/0 also...
Get a good AGM under the hood and 1-2 more in the back. Do the Big3, and connect all the batteries in all 0 AWG wire. If I may ask why do you need to run this amp? This amp draws alot and puts out ALOT and shouldn't be used by someone that doesn't have much experience. Not trying to sound like a prick.
Johns.jpgSuburban Coming Soon
3500d.1 is 4300 watts at 1 ohm..
big three..
one GOOD battery in the back and one decent batt up front.. / story.
if you still have voltage issues
get your alt rewound at a local rebuild place. for aorund 100 bux.
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
tuned to 25 hz... stay tuned.
blazer
stroker 15
brutus bxi2006d terrible voltage drop
145.4@38HZ... SEALED LEGAL
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
my house is louder than your car...
do you have the big 3 already done and are you looking into a high-out put alt?
good suggestion, and WRONG, you dont need a damn h/o alt for 3500 watts unless you have a whimpy 90amp alt, my AQ runs just fine at 1ohm on a stock alt, and thats only with 1 extra battery, that being a kinetic 1400, but inall youll really only need 1-3 batterys, depending on how big your stock alt is, big3 is a must! 0g is also a must!
How am I wrong.... And what that amp has the potential to you are not achieveing it with ur factory alt and a single battery...i only made a suggestion for him and were to start......
he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick:
I'm using it to power two 18" xls.
ok well with the voltage control that vehicle has i'd get a h/o to be safe for sure
If you are able to spend $500, get the alternator. It takes power to make power, and the alternator is the source of power for everything electrical in a vehicle.
Ok, well another question i guesss. Would i be able to run the amp off of just the batteries until im able to get the new alt? or would you just not chance it
It should be fine as long as you don't let voltage go below 12.5 or so. The beauty of the volume knob is that you can control this.
  • Who's Online   0 Members, 0 Anonymous, 1511 Guests (See full list)
