4th order idea
mbdblue
I was just working on a 4th order design for 2 12's. I talked to Sanitarium about the design I came up with and he said it should work.
2.72 cubic feet ported subs in the ported side tuned to 45hz
.76 sealed per sub
http://www.youtube.c...er/SmallTownSPL
2002 Chevy Blazer
Substage: Shhh, its a secret ;)
Mids and Highs: Stock-Going to change soon
Amp:MTX 92001
Wire:1/0 Welding cable
Electrical:Stock
http://www.stevemead...__fromsearch__1
I hope she was meaning that to you. Any who.... You dont say you wanna have dinner in the first damn post. talk to her first. I say find out if the status was torwards you..
Here try this...
"Hey hows it going :)( notice smiley face makes everything better ) I saw your status. "You are far from usual".... So is my dick... Wanna Fuck tommorow???"
Or send her message saying "hey" she replies back "hey" when this happens reply Wanna fuck (INSERT ADDRESS HERE)
Quote of the SPL Creed ; back in the day my girlfriend gave me a choice between her and my love for car audio, I told that bitch I've made harder decisions at the Coke machine. :)
when figuring the port, the port area should be like 10-16 per cube of the REAR chamber correct? if so then for my 2 12's i'd need from 25-40sq inches which is TINY
Johns.jpgSuburban Coming Soon
1.5 seems little big for 12s ...i used 1.5 sealed for my 15s and ended up having to shrink em a little
i usualy use .75-1.25 cube per 12 myself (usually closer to 1")
go with a 2.5/1 ratio tuned to 47sh hz
so example
1 cube sealed x 2
so
2 X 2.5 =5 +2 -7
so youd need 7 cubes before displacement
or you could do a 2/1 ratio to save some space
could you expand on that equation a little? 1 cube per sealed, so thats 2 cubes and the center box is 2.5 cubes? how did you get 7 cubes?
thanks alot for the feedback. Im kinda goin in blind :pardon:
oh and I found a good amount of info on this link:
link to 4th order info
you have your sealed partition which is 2 cubes total (for both subs 1 cube each sub) then you got your ported partition which is 2.5 cubes per 1 cube sealed
so think of it as 2 box's your back box which is your sealed box (2 cubes) and your ported box which is 5 cubes so you would add those 2 up and your left with 7 cubes
like so
AH! okay I gotcha now. I was getting confused by the ratio :trippy: . thanks alot man, now to do a little tweeking. I might have to drop it down to 2:1 just for space issues. or else Ill wack my elbow on it when I get in the car haha
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
I almost forgot, would 47hz be a good number to tune to for daily and on the meter? Im looking for both, and was thinking of sleeving the port
do u know what ur car was peaking at before?
im gunna try a 4th order for my lvl 5 12" =].
the plan is .8 or .9 sealed & between 1.5-1.8 ported @ 48hz.
ill let u know how it turns out if u remind me lol.
m_8e0e9deb0e2a020a7ff1bf0d3a6c3306.jpgth_140x100square.jpgth_140x100rev2animated.gifsoundigital.pngth_Banner_140x100.jpgn221468318568_2854.jpg
No, you would want to figure it with the size of your ported chamber.
So if you had 3 cubes sealed and 9 cubes ported you would use the size of the potted section to determine your port area.
So your port area could be between 90 - 144 going for 10 - 16 per cube.
Some say bigger, I personally use a 14:1 ratio and sometimes 11:1.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
I do indeed...it was peaking at 53hz before. :good:
I like going with sealed:ported ratios in the 1:1 to 1:2 area...even 1:2 can be pretty peaky with certain subs. If you're wanting a big peak, then by all means go for 1:3 or something like that...just don't expect a smooth response curve with it. But for a musical box, it's best to not have a huge ported chamber, in most cases.
Without knowing what subs you're using it's hard to make a solid recommendation though.
Ryan Miskin - owner of RAM Designs
I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script>
2200+ designs since March 2011...
ah ok....Im actually goin more towards 1:2 ratio due to lack of space. the subs that Im using will be T2000s on 2k a piece daily then 4k a piece for comps.
  • Who's Online   0 Members, 0 Anonymous, 852 Guests (See full list)
