big-mark-g Posted February 25, 2011 Report Share Posted February 25, 2011 hello, i cannot get my head round how to wire all 6 of my dual 4 ohm voice coil subs... can any1 help me with an image or a in depth explanation on how to do it... thanks , i want them as low as possible but no lower than 2 ohms as thats all my amp is stable at, thanks again Quote Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted February 25, 2011 Report Share Posted February 25, 2011 (edited) Wire all the coils in parallel, then wire the subs in parallel in pairs(now there are 3 pairs of dvc4s wired to 3 1 ohm loads). Then series them together aka 3 ohms. Edited February 25, 2011 by I like kicker Quote Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
uhoh_45 Posted February 25, 2011 Report Share Posted February 25, 2011 go to the bottom of the page Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted February 25, 2011 Report Share Posted February 25, 2011 go to the bottom of the page None of those would work, he needs a final load no less than 2 ohms. Quote Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
uhoh_45 Posted February 25, 2011 Report Share Posted February 25, 2011 with imp rise you'll be well over 2 ohms so 1.3 should be fine depending on the amp Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
RooTxBeeR Posted February 25, 2011 Report Share Posted February 25, 2011 Guess he needs another amp? Quote On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5 Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted February 25, 2011 Report Share Posted February 25, 2011 (edited) Edited February 25, 2011 by I like kicker Quote Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
big-mark-g Posted February 27, 2011 Author Report Share Posted February 27, 2011 hello, thanks for your replies, you say about the amp, its a kicker kx700.1 Quote Link to comment Share on other sites More sharing options...
EclipseChris Posted February 27, 2011 Report Share Posted February 27, 2011 hello, thanks for your replies, you say about the amp, its a kicker kx700.1 Good luck with that Quote i resolve to be a nicer moderator. Tercel build R.I.P. Eclipse build Old New V-Dub My feedback. Link to comment Share on other sites More sharing options...
bkolfo4 Posted February 27, 2011 Report Share Posted February 27, 2011 Wire all the coils in parallel, then wire the subs in parallel in pairs(now there are 3 pairs of dvc4s wired to 3 1 ohm loads). Then series them together aka 3 ohms. Correct. Like this: Quote Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz. Link to comment Share on other sites More sharing options...
