ok, i just plugged the numbers into the torres calculator that is on here and i came up with a 40.65Hz frequency tuning per sub. so you should look at a 35-40Hz subsonic filter. Normally you would only go 2Hz less than your port tuning and NOTHING more than that because you can bottom out the subs and burn/blow the coils. If you havent already id recommend turning OFF any bassboost you may have on and for setting the gains on your amp make sure your headunit's EQ is set to FLAT. if you do not have it set to flat it will really screw it up when you try to tune the amp with the dmm later on. Unless you have an oscope i really dont recommend messing with any bass-boost or loudness equalization because they always cause a lot of clipping on your signal which in turn destroys your subs/speakers.
Thanks a lot man, I'll adjust it now. Is there any quick way to get the box to a lower hz tune? I'd like to be at 32ish.
Make your port longer
c'mon now, if i was shooting an 8 year old, it wouldnt be MY 8 year old.
i recently got a Pyle PL1590BL and i was building an enclosure for it tuned to 25 hz. i didn't have any tools to cut a circle so i hit it with a big hammer.
2003 Infiniti G35 Sport Sedan
Build in Progress
I mean I like low bass, for example, as a reference the song "white girl" by USDA hits I believe 20 Hz. I hear my subs picking it up just not really projecting it like I think they should. Do I just need a bigger box? Or what?
the easiest way to get the tuning down lower would be to screw with the port length. in your case you are only going to be able to get lower tuning if you make the port longer which would mean to get some board and make like a l shaped port because a longer port in your case would make a lower tuning. you cant really make the port wider to get a lower tuning.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
a bigger box will help a little with that but the tuning is what your getting screwed on. your box is tuned too high and DO NOT play songs that are that low with your box. you are bottoming out the subs. you may not hear it but you are literally reaching/exceeding the handling of the subs and are getting them ready to break.
My port is basically an inch less deep than my box. Due to the 1 inch wood it's built with. So I'm just gonna have to make an attachment and just align it on the outside with the port? How much longer? Thanks guys, just want the most out of these until I man up and buy the Fi btl or dc lvl 4's.
i figured it out as being if you cut a board that is another 19 inches long will drop you down to 34Hz so the 30Hz is impossible with your box.
What would you do? What dimensions would I need for 30Hz? I have a trailblazer SS so room isn't an issue.
ur gonna have to rebuild your box. are you up to that first?
  • Who's Online   0 Members, 0 Anonymous, 480 Guests (See full list)
