kickass audio Posted February 27, 2011 Report Posted February 27, 2011 yes pretty much thats what i was getting at. yea the n2 would suit your needs pretty well. and yes you can use the xtrpros in the box for the btl BUT they have a higher risk of bottoming out a little sooner if ur throwing a ton of power at them so dont get volume happy with them. id keep the setup u have right now but ditch the box. i know how it goes, i myself have a prefab box for my solox because my dad insisted i was too stupid to know how to build a box and that i had no patience for it (im proving him wrong this spring tho) and he insisted i get a prefab box to get bass as fast as possible so i would shut up with nagging him to let me use the table saw. mind you im gonna be 20 and he doesnt trust me with a simple table saw. its not like im gonna be like "ooooo sharp blade spinning fast, let me put my hand in there" lmao. But id say to do this: 1.) Make a bigger/better box for the btl n2's 2.) temporarily put the xtrpros in the box until you can afford the btl's 3.) temporarily use your current amp for the xtr's until you can afford another bigger amp to give the btl's the power they crave 4.) upgrade your power and all that good stuff. You have a good amount of work on your hands just to let you know especially for the electrical upgrades. if you run one alt and one batt on amps that will make the btl's happy you will stall the car out and fuck it up big time. 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
vettetruck Posted February 27, 2011 Author Report Posted February 27, 2011 yes pretty much thats what i was getting at. yea the n2 would suit your needs pretty well. and yes you can use the xtrpros in the box for the btl BUT they have a higher risk of bottoming out a little sooner if ur throwing a ton of power at them so dont get volume happy with them. id keep the setup u have right now but ditch the box. i know how it goes, i myself have a prefab box for my solox because my dad insisted i was too stupid to know how to build a box and that i had no patience for it (im proving him wrong this spring tho) and he insisted i get a prefab box to get bass as fast as possible so i would shut up with nagging him to let me use the table saw. mind you im gonna be 20 and he doesnt trust me with a simple table saw. its not like im gonna be like "ooooo sharp blade spinning fast, let me put my hand in there" lmao. But id say to do this: 1.) Make a bigger/better box for the btl n2's 2.) temporarily put the xtrpros in the box until you can afford the btl's 3.) temporarily use your current amp for the xtr's until you can afford another bigger amp to give the btl's the power they crave 4.) upgrade your power and all that good stuff. You have a good amount of work on your hands just to let you know especially for the electrical upgrades. if you run one alt and one batt on amps that will make the btl's happy you will stall the car out and fuck it up big time. Ok sounds like a plan. Just an FYI , I wouldn't power the n2 to the extent of vehicle damage until I upgraded power components. I guess when you throw the dimensions my way I'll go buy some wood and knock it out.
kickass audio Posted February 27, 2011 Report Posted February 27, 2011 ok that sounds good. i wouldnt go personally more than 1500 rms with stock electrical. i had a 150 amp alternator in my car with an xs power s3400 and i had voltage drop to 13.2v but it was only for a few seconds. it was still beefy. the biggest thing you can do to combat voltage drops is to do the big 3 and since ur gonna run n2's do all 1/0 wire. i have all 1/0 and i am going to improve on my system by adding a 20 foot ground wire from the front batt to my rear batt(s) 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
kickass audio Posted February 27, 2011 Report Posted February 27, 2011 ok, i came up with a box for you. now im sure someone on here will say its too small but i can fix it in 2 seconds if it is. but i have it as follows: wood thickness: .75 (3/4 inches) (note: i did not include the displacement if you were to make window braces like i am doing with my box but i would highly recommend doing 2 of them if possible) outer dimensions of the box: 18 in high 33.5 wide 23 deep Port dimensions: 19.25 high 2.25 wide 18 long _________________________________________ gross volume: 6.57 cubic feet port volume: 1.17 cubic feet Net volume: 5.26 cubic feet tuning frequency: 30.05 Hz _______________ This was all for if you do get the two 15" fi btl n2's 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
vettetruck Posted February 28, 2011 Author Report Posted February 28, 2011 ok, i came up with a box for you. now im sure someone on here will say its too small but i can fix it in 2 seconds if it is. but i have it as follows: wood thickness: .75 (3/4 inches) (note: i did not include the displacement if you were to make window braces like i am doing with my box but i would highly recommend doing 2 of them if possible) outer dimensions of the box: 18 in high 33.5 wide 23 deep Port dimensions: 19.25 high 2.25 wide 18 long _________________________________________ gross volume: 6.57 cubic feet port volume: 1.17 cubic feet Net volume: 5.26 cubic feet tuning frequency: 30.05 Hz _______________ This was all for if you do get the two 15" fi btl n2's Ok cool one thing confused me though... How can the port be taller than the box?
kickass audio Posted February 28, 2011 Report Posted February 28, 2011 good call. im sorry bro didnt notice that. lemme fix it. also you should get a little bigger box than that so let me fix it. good eyes. 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
kickass audio Posted February 28, 2011 Report Posted February 28, 2011 wood thickness: .75 (3/4 inches) (note: i did not include the displacement if you were to make window braces like i am doing with my box but i would highly recommend doing 2 of them if possible) outer dimensions of the box: 18 in high 36 wide 23 deep Port dimensions: 16.5 high (this is the height inside the box so its easier to build) 2.25 wide 11.5 long _________________________________________ gross volume: 7.08 cubic feet port volume: .71 cubic feet Net volume: 6.23 cubic feet tuning frequency: 30.16Hz 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
MrSoHeavySPL Posted February 28, 2011 Report Posted February 28, 2011 I mean I like low bass, for example, as a reference the song "white girl" by USDA hits I believe 20 Hz. I hear my subs picking it up just not really projecting it like I think they should. Do I just need a bigger box? Or what? just so you know white girl peaks at 32 and 53, kinda off topic but yea haha 96 GRAND MARQUIS 2 Kole Kmx 15s 6.0 A.E. box tuned to 42Hz 1/0g power and ground Huge Duralast batt. Stock 130a alt Amplifier - Dual XiA2460(hardcore p.o.s.) Head Unit- Kenwood KDC-X693 AudioControl Three.1 Audiobahn bass line driver Teh Big 3 in Kollosus Fleks 1/0 Funny Youtube Shit MATUXAZ 2 weeks ago "In wikipedia i found that this sub in 1997's unofficial private SPLdB drag was burned down the dB meter! The dB was over 300 and the system burned down. Actually, 300dB is only about ¼ of this prototype sound level." I don't know anything about guns... so when I saw the title I thought, "I wonder what kind of woofer the AR-15 is?" *laughs* Twisted, I would stay away from that guy, the next video he uploads could be you tied up in his living room while being forced to watch him "swag and cook" in person, lol.
kickass audio Posted February 28, 2011 Report Posted February 28, 2011 but if you get 5 of the vent holes for the box and since he is using 15's it will add bass. he will be the db king. lol. and no vette im not insulting you. 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
vettetruck Posted February 28, 2011 Author Report Posted February 28, 2011 It's all good, you've helped me quite a bit man. What's this 5 vent holes you speak of?
