my 08 malibu ltz wont crank up
i dont know if this is the right section,
but here it goes
I Had my car parked outside my house for 2 days with out a battery in it.
Feb. 24 2011 and decided to put the battery back in on feb 26 2011.
The reason i took it out is because i was modifying the plastic cover to fit
a xs d3100 in the front. I finished modifying it in less than 30min. but started raining harder
so i couldn't work right.The rain cleared yesterday(feb. 26-11)
That's when i took advantage and put the battery back in.nice and charged.After everything was all
hooked up right,my car wont crank up!
All the lights in the ignition works,lock & unlock features works,headlights,etc.
but the only thing that doesn't let me do is turn on the car.
What do you guys think it might be,I'm planning on taking it to a shop on monday.
But i want to make sure if it can be a little stupid thing(easy fix) first before i take it in.
suggestions,opinions,etc. is more welcome and appreciated!
that's all for now
TEAM FLEX ISSUES,TEAM DC AUDIO
2000 Silverado Ext 1500 v.3
(Walled Silverado)
4 DC Power 270a Alts on A DC Power Quad Alt Bracket
XS Power VCM,Stinger Volt Meters
4 AA Mayhem 18s
2 DC Audio 9.0ks Strapped
1 DC Audio 175.4
4 Selenium 6.5s & 4 Selenium 8s
4 Selenium Super Tweeter st350s
72 SQ Ft Of Stinger Roadkill Expert
Alpine CDA 9887
XS Power d3400(Hood),6 XS Power d3100s(Bed)
& much more.....
2011 Meca CA State Champion & State Record Holder In M5
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
BUILD LOG.....YOUTUBE CHANNEL.....FEEDBACK
damn
well someone pm me that it might be my stock alarm,
also one of my team mates said the same thing
i checked my dash right now and it started saying
service esc
whatever that means
(Walled Silverado)
4 AA Mayhem 18s
1 DC Audio 175.4
Alpine CDA 9887
& much more.....
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
U can reset, by disconecting both batt cables and holding them together for 10min.
i'm on my laptop
doing everything that you guys are telling me to do.
shiz sucks
but got all day trying to fix this issue
(Walled Silverado)
4 AA Mayhem 18s
1 DC Audio 175.4
Alpine CDA 9887
& much more.....
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
Double check you hooked up the cable that goes straghtto the starter.
It will be a 6awg wire,pos.
Now triple check it.lol
Service ESC is the Electronic Stability Control, idk why that would not let it start.
My mom has a '10 LTZ and hasnt had a problem with hers, sucks that you're having an issue.
With the battery unhooked, try and crank the car a couple times to get any remaining charge left in the system out.
You might also want to try and call a GM Dealership and see if they can talk you thru it over the phone...some dealerships are nice like that.
First System
2002 Impala LS 3.8L V6, 128,365k miles.
Alternator: DC Power 190Amp H/O Alternator
Headunit: Kenwood KDC-BT945U.
Speakers: MBQuart 6.5" Comps, 6x9 3-way.
Amplifer: Eclipse 3322 on front 6.5 components, and a Infinity Kappa One @ 2ohm- 800w
Subwoofers: 2 REAudio SRX12D2 wired to 2 ohm.
Box: 3.1cuft box tuned to 33hz. sealed off to cabin
Big 3- done with all Knukonceptz KCA 0 gauge.
Don't drop below 14.1v at full tilt. :)
this is the main three things that pop up
on the messenger window
and the funny one
i had half a tank of gas when i had it parked outside my driveway
so i know this one can't be right lol
(Walled Silverado)
4 AA Mayhem 18s
1 DC Audio 175.4
Alpine CDA 9887
& much more.....
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
UPDATE:
there was another message
it said
esc off
but it only showed once
it's not popping up again
(Walled Silverado)
4 AA Mayhem 18s
1 DC Audio 175.4
Alpine CDA 9887
& much more.....
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
