the quarters are completely covered in deadener and in some spots even 2 layers thick lol. Im ordering mores and going to go 3 layers thick in the trunk and 1 layer thick every where else.
lower tuning is just hard. I was surprised how loud 145 sounds at 35hz, and how quiet 145 sounds at 50hz.
-= 2005 Tahoe LT =-Head unit: Pioneer AVH-X5500BHSSource: iPad Mini in dash
Subs: 2 T1 12's
Sub Amp: T1500-1bdCPWire: Rockford Fosgate 1/0 awgSignal Cable: MonsterFronts:Stock Bose for now:)Rears: Stock Bose for now:)MIds/High amp: Stock Bose for now:)
2005 Tahoe Build Log: http://www.stevemeadedesigns.com/board/topic/172529-2005-tahoe-my-17th-vehicle/
2001 Monte Build Log: http://www.stevemeadedesigns.com/board/topic/160030-2001-monte-carlo-my-16th-car-lol/page-2#entry25309381997 Tahoe Build Log: http://www.stevemead...oe-6-15-rf-15s/2001 Impala Build Log: http://www.stevemead...katzkin-inside/SMDSig3-26-12.jpg
And you failed to mention this an hour ago when you were over here why? Lets get down, I NEEDSTA do the roof!
2001 Bravada (2wd) Pewter on 24's
JVC KW-AV60BT
10 Alpine Type-S 6.5s
2 PSI/BTL 18's @ 32Hz
2 Rockford Fosgate T25001-bd's @ 1-ohm each
Rockford Fosgate T1000-4
Rockford Fosgate T400-4
Rockford 3Sixty.2
Yellow top up front, 2 9a31s in the back
LOTS of AT 1/0
Python 991
350 Amp Singer Alt
"Build Log"
My Facebook
My YouTube
i didnt see the video or read anything but...cool story
and the reason your being a cock tonight is?
Car looks great, love the color combo along with the wheels and tint! I can get my wing to flex like that too, these impalas get loud pretty easily...
With 130k miles on the clock, you may want to go ahead with doing a coolant flush, making sure the plugs and wires have been changed, ONLY go with AC Delco as these cars like to misfire with any other plugs/wires, on the 3.8 the UIM/LIM (Upper intake manifold, lower intake manifold) gaskets tend to go bad, and the coolant elbows should be replaced too. If you do a coolant flush, don't re-fill with dexcool, change to the green coolant instead.
Otherwise I LOVE the car....you should look around junkyard for junkd impalas with leather interior / heated seats! They're great...
Yeah I'd expect to have to change a coil or two before you hit 200k. I had good luck with bosch plugs on ACDelco wires (YMMV) in my 3.8L Regal before it died at 255k. Yeah I agree, down with Dexcool, you need to change coolant at 30k no matter what. 5 years life spec for dexcool is a crock... no coolant keeps dirt out of the system and that's why you flush.
2007 Pacifica
Teddy if I play my cards right, I won't be paying for the deadner. Yea I need to get a flush asap.
Subs: 2 T1 12's
Updates. I made some trim panels for my trunk. What do you think?
Subs: 2 T1 12's
I like that, looks clean and classy.
Did you just replace the stock trunk lamp with a blue one? Looks crispy :drinks:
2007 Pacifica
I replaced the bulb with a 20 SMD LED light strip from my local AutoZone. Thanks man, its amazing what a few hours of time can do, looks so much better now.
Subs: 2 T1 12's
Got more work done today. Got my new alt installed, Voltage is ~13 @ idle W/O load and stays ~15 @ 1200 RPMS @ full tilt. Got my calipers painted orange to match the stripe. I also bough the "sport" cluster for my car that includes the Tachometer.
Pics.
Subs: 2 T1 12's
mounted my SVMB inside my cluster when I did the swap. My car just shaved off 80,000 miles ;). I am having it reprogrammed.
Subs: 2 T1 12's
I soldered my diode mod in today I'm only using one diode now. The new alt had a more voltage than the stock alt so I don't need two.
Subs: 2 T1 12's
