i have a DVD camcorder that i decided to use because its better at nite then my usual camera.......but now i cant get last nites "footage" off the cam and onto the computer so i can edit it. Anyone know an easy solution?
Follow my Tweet (Twitter)
when you put the dvd in the computer does it show up like a normal dvd does with the vob and everything?
try ashampoo movie shrink and burn
can you plug it into your computer? if you can plug it in and open up windows movie maker and import the video straight from the camcorder while it plays the dvd. im not sure if it works the same as mini dv but i remember all i had to do was plug it in and click import then hit play on the video camera and the video would show up on the computer screen and id hit record when i saw what i wanted to be recorded on the comp.
Nero is supposed to have the ability to capture and convert your dvd. If that doesn't work walmart sells a $4 program called dvd to vcd that will do what you want.
