Guest Posted March 7, 2011 Report Posted March 7, 2011 Well i also want good electrical so i guess i would pay for two batteries one up front and one in back just more stress on my alt though? not necessarily the extra battery helps voltage so the alt doesnt work so hard trying to recharge the main battery That makes sense so the volts would actually go up? no...you will still drop, just not as much.
Autruche Posted March 7, 2011 Report Posted March 7, 2011 Doing the big three, and having a good strong battery up front (or just add a second one) will do you alot of good. That stock alternator will have no problem with charging 2 batteries, I wouldn't run more than 2 batteries on a stock alternator though. I wouldn't think of a bigger alternator until you'd get up to about 3000rms. Just what I've learned from experience. If you're worried about clipping those AQ amps come with a clipping indicator light, so run a tone to tune it, and adjust the gain (with sub hooked up and the car running) until the light comes on, then back it off a little until the clipping indicator light turns off. Your best bet is to use an oscilloscope to tune your amp, but the AQ clipping light is better than nothing. Need Test Tones/Sine Waves? Click Here!My Saab 9000 build1993 Saab 9000 Aero 5spdPioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE AudioJust Say No To Rear SpeakersJust Say No To CCA WireReal Men Drive StickHit me up on Facebook, if you want
Winn Posted March 7, 2011 Author Report Posted March 7, 2011 Well i also want good electrical so i guess i would pay for two batteries one up front and one in back just more stress on my alt though? not necessarily the extra battery helps voltage so the alt doesnt work so hard trying to recharge the main battery That makes sense so the volts would actually go up? no...you will still drop, just not as much. Go up as in whenn your playing your system and it drops if added a new battery ut wouldnt drop as much as before. But i thought it would hurt your amp if your volts are too low You know how you avoid that? Man the fuck up and bang her best friend sister mom cousin worst enemy and never look back. JUST SAY ANTI-AUDIOPIPE
crunkjuice1 Posted March 7, 2011 Report Posted March 7, 2011 If you were dead set in beginning I know DCpower has a 180 amp alt for around $400 then see if you can fit an xspower S3400 under the hood. Its your money if you want to spend it go for it.
Winn Posted March 7, 2011 Author Report Posted March 7, 2011 Im not dead set on nothing im just trying to find a decent route to take my electrical so i dont fuck up my amp... 400 for a 180 amp? wow thats quite a bit. Im leaning torwards kranny's susgestions You know how you avoid that? Man the fuck up and bang her best friend sister mom cousin worst enemy and never look back. JUST SAY ANTI-AUDIOPIPE
R3nOSlaPP Posted March 7, 2011 Report Posted March 7, 2011 Well i also want good electrical so i guess i would pay for two batteries one up front and one in back just more stress on my alt though? not necessarily the extra battery helps voltage so the alt doesnt work so hard trying to recharge the main battery That makes sense so the volts would actually go up? no...you will still drop, just not as much. Go up as in whenn your playing your system and it drops if added a new battery ut wouldnt drop as much as before. But i thought it would hurt your amp if your volts are too low yes you can get an amp to go into protect or thermal if the volts are too low Vehicle: 2017 Chevrolet Silverado High Country Electrical: 320A Singer Alt, (2) Limitless Lithium 15ah, Full Throttle FT680-48 Speakers: Stevens Audio SA 6 (ACTIVE), Audio Designs 3” Subwoofer: (4) B2 Audio XM 8’s Amplifiers: (2) B2 Audio Rage 2500.1, (1) B2 Audio Rage 1200.6 Processors: NavTv M650 (integration), Helix DSP Pro MK2 Silverado Build Log
Guest Posted March 7, 2011 Report Posted March 7, 2011 Go up as in whenn your playing your system and it drops if added a new battery ut wouldnt drop as much as before. But i thought it would hurt your amp if your volts are too low your voltage will never ever ever increase by adding batteries. the voltage regulator on the alternator controls the maximum amount of voltage your alternator will output (changing it wont change how much voltage you drop). your statement is half correct. you wont lose as much voltage by adding another battery, but losing too much can harm your amplifiers if you're stupid about it. just listen to what me and like 5 other members said. get a battery in the back, do the big 3, get a battery up front if you want as well, and watch the red light on the bass knob. you're making this seem like your car is going to blow up if you dont add enough batteries or if you have too many.
SPLadd1ct Posted March 7, 2011 Report Posted March 7, 2011 Get yourself the biggest alternator you possibly can under the hood. More amps = less voltage drop. Also grab the biggest XS Power battery than you can fit under your hood. You'll be good to go for that Audioque 2200D. people are right, this forum DOES have a thing for unneeded electrical upgrades. he doesnt need to dump $4-500 for an alternator for a freaking 2000w amp dude. the big 3 and a battery or two in the back can do him just fine. ive seen a 2200 run on .5 DAILY on a stock electrical system with 1 battery in the back and a like 100amp alt. i have also seen a 2200 run on 1 ohm on a stock electrical system with 1 battery also. He said he wants his voltage in the 13-14's. With what I recommended he will be good to go =) 2011 Ford Ranger Sport 4.0 v6 2 sundown audio prototype nsv4 15s crossfire 4k wired to 0.4 ohm 15 banks of maxwell 3.0 caps @ 18v triple alts (x2 us alt 250's, x1 singer 320) 153 at 23hz
Guest Posted March 7, 2011 Report Posted March 7, 2011 He said he wants his voltage in the 13-14's. With what I recommended he will be good to go =) im not trying to shoot you down, but i will state again that i have seen a 2200d wired to half ohm and i will quote what the owner said, "i had a voltmeter in my factory cluster, its got a line for 14v and never strayed to far off that" "maybe like 13v" "redtop and 1/0 power and ground"
Winn Posted March 7, 2011 Author Report Posted March 7, 2011 Well i also want good electrical so i guess i would pay for two batteries one up front and one in back just more stress on my alt though? not necessarily the extra battery helps voltage so the alt doesnt work so hard trying to recharge the main battery That makes sense so the volts would actually go up? no...you will still drop, just not as much. Go up as in whenn your playing your system and it drops if added a new battery ut wouldnt drop as much as before. But i thought it would hurt your amp if your volts are too low yes you can get an amp to go into protect or thermal if the volts are too low Well my audiopipe didnt go into protect mode... She started smoking in the back You know how you avoid that? Man the fuck up and bang her best friend sister mom cousin worst enemy and never look back. JUST SAY ANTI-AUDIOPIPE
