04 GTO System 4/17 UPDATE Pg.4 06 GTO 500RWHP
Damn, I need cams.
Sounds good, I was waiting for a rev or two though.
Thanks I did rev it but when i checked my camera i ran out of space so it didnt save. Ill try and get another video.
Curious about the motor. Is it like a limited edition from the factory? Or full custom build?
Its fully custom the original owner had this built and sold the factory ls2. It consists of a ls3 block that was then stroked to 418 with callies crank and rods, mahle pistons, 4" stroke. It also has ported l92 heads, ported ls3 intake, big cam.
  • 6 months later...
I had said I wasn't going to put a system in this car but I really missed the bass so I removed everything from the old car and put it in this one. I also changed some things and got some new stuff to try out. Im new to having a 4ch amp and components so I wanted to start off with a CT Sounds 60.4 and some MB Quart ONX components. I haven't installed the components due to them being a bit to big for the plastic that holds the stock speakers so for now I just wired the stock speakers to the 4ch. I haven't set the settings up yet but it sounds better than before already. I also changed how the amps were held since I needed to add the other amp.
Here is the old amp rack
I added a new section and covered it with some left over headliner fabric. I oversprayed the glue a bit and messed it up but it will never be visible anyways since it goes under the sub box in the spare tire well.
New stuff
Amps mounted
Running the rcas. The 4m rcas were a lot shorter than I imagined and I had to run the across just to reach.
Experimenting with some Damp pro im going to add more.
Front door and speakers
Amps in spare tire well
Old sub and box from other car. Im looking at upgrading to a SP4 but for now this will do.
I'd buy the fuck out of your car.
MY BUILD
1998 Ford Explorer 2dr sport
1/0 Big 3 1/0 everything
Alpine cda-9884
Crescendo CZ components
(2) Crescendo bc2000's
(2) Jolt 150ah
(2) Yellow top optimas
(1) Juicebox black cherry addition
(1) Mechman 270 avbm
miss my bc5500 and (4) 15's
You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
  • 4 weeks later...
Got some more stuff done that I forgot to post about. I finally got the components in there alright but I wouldn't recommend them to anyone. I know n8 hates probably hates these but for now they will do.
Had to cut the weather shield for the speakers.
