advise and tips
can you guys give me some tips and advise to build a good box. im debating between building the box myself or have someone build it for me. if i build it myself what are some things i need to know before i start. because i cant afford to screw up lol. i dont know what to do. im stuck
Make sure all cuts are even and to the T, make sure u seal it up real well, make sure it is properly braced either with dowels or all thread, 45's in the corner never hurts either. Screws Glue Caulk, and either some paint or Carpet thats all you need.
06 Impala SS
Kenwood Excelon DDX593
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
Mechman 320a Alt. w/ Big 3
Lots of Second Skin Damplifier
Under Construction for 2017
this is for one sa12 so i dont think bracing is necessary. but i will double baffle it. thanks man
sometimes it does.
all i can say about building a box is to measure. a lot
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
*Measure 3 times cut once
*Always make you cut then make you measurement for the next piece(So you pieces dont keep getting the width of the saw smaller every cut)
*Dont be shy with the glue, if it gets a little messy you can always sand if off later.
*Dont go crazy with screws, they are just there to hold the box together while the glue dries
*When using screws space em 4-5inches apart
*When using screws always predrill, you dont want split wood
*Bracing is always good and a Single 1" Dowel Rod can brace you box Horizontally and Vertically
*Make sure to use some Caulk/Silicon to seal all the inside edges of the box, even though it may look solid each small space counts
*Routers are awesome, if your gonna be building boxes often its a must have
Thats all I can think of At the Moment.
¿ǝɯɐƃ ǝɥʇ
nice guys thanks a lot. i only have a jig saw and drill of course. no table saw or router :/ but i just need to see when my boss if free so i could go over and use all his shit. he has everything lol
Good info here. 45s can hurt though.
Straight cuts are important. Birch ply is easier to cut than MDF and its stronger too. But more expensive.
Look at plenty of build pics here for ideas.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
woop thanks ed!! and how do 45s hurt?
MDF will EAT blades for jig saws and bits for routers
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
45's aren't a given for making a box louder. It's a test, try and retest kind of thing. Or if you are familiar with the box design you are working with then that helps too ;)
I personally think mdf is more forgiving for new box builders. Plus splinters suck.
