DC LVL 6 2010 Mustang GT *TL Scores pg.73*
So in the future will we see 2 level 6 12s on a 12k? Or are we planning on an additional 7.5
he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick:
Its a looonnnggg way off, but when I add the second 12, they will be xl's or 5's, still on the 7.5k.
SMD Super Seller
My Feedback Thread
Wow. I think thats the longest post I actually read all the way. Thanks for taking interest.
I tend to write long posts.. I catch a lot of crap for it on most forums.. haha
Cost is not the delay on boosting my car. I keep going back and forth in my head about the warranty implications if I do it. Not worried too much about the motor, but the transmissions in these can have issues. It'll happen eventually. That being said, it is surprisingly quick from the factory. Opening up the exhaust and getting my flash tune dialed in really livened it up. The 3.73's are factory, so they're staying. Control arms, drive shaft, and clutch/flywheel will get done with the power adder, gotta wait to see how the car loads with the system in before tackling springs.
I understand the warranty thing.. mine was out of warranty when I did the supercharger. As for the trans and rest of the drivetrain, the 5 speed is good for about 800 rwhp, the clutch good for 500 rwtq, the rest good for 800 easy.. The engine is the weakest link, good for around 11 psi boost before things get shady.. I wouldn't go above 10 psi.. Don't go by RWHP ratings for engine reliability as each form of boost has different efficiencies.. you can get 500 rwhp from a turbo at 10 psi, but the same 10 psi with a twin screw or centri will give you 450ish and from a roots, 430ish.. the internals will have the same stress from that amount of boost, given that cams, heads, and exhaust are equal. Any more than that and you should build the engine, any less and you will most likely never have a glitch.. The system will probably settle the back end nicely as it is about 1" too high stock.. eliminate that 70's rake and level it out.
As for the system, 10's didn't do it for me. Not just on the meter, I like the sound the 12 had better. And it will be 2 12's in the future, that's all I can do without a wall. Oh and the tuning of the new box is 34, but I may raise that a little after plotting the design using bassboxpro.
Everyone has their preference, but in the years I was installing, I found that a 15 in the right box can be snappier than any 8 or 10, and an 8 or 10 can be looser and boomier than any 15 or 18.. it is all about the enclosure in my book. But hey, if you like the 12 better, all the more reason to go that way.. I would still suggest loading it in some fashion.. if not to the floor or side, then build your box to load it.. you can still go 3rd order and just load it into an open chamber, if you can get the room.. Just my opinion again.. ;)
Good luck with it..
Ok, I figured out how I'm going to mount this amp rack, and got it predrilled and wrapped. Same carpet as the trunk, trying to be just a little pretty with it.
My little helper
I'm gonna get it in after the Raiders game. Even though they're suckin'.
SMD Super Seller
My Feedback Thread
Looking really good man!
1998 SS/T Ram Build Log
- Kenwood KVT-514 and KNA-G510 Navigation
- 2 DC Level 3 12"
- Components???
- Sundown ???
- Sundown???
- Knu Konceptz
- Second Skin Dampy Pro
- XS D6500
looks pretty dope bro.
looks nice man! i spy your poodle too.
Thank you guys. Its a simple idea, but it actually looks WAY better than I thought it would. Hardest part was getting it to sit right, because of that center brace running up the middle. Now I get to put holes in it for wires. Yay.
SMD Super Seller
My Feedback Thread
  • Who's Online   0 Members, 0 Anonymous, 2258 Guests (See full list)
